1999 7.3 fuel problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-13-2014, 01:54 PM Thread Starter
I HAVE 1999 7.3 THAT HAS 375,OOO MILES ON IT. THIS TRUCK WAS USED IN A LOGGING OPERATION, SO HARD MILES. WHEN I FIRST BOUGHT THE TRUCK I CHANGED ALL FLUIDS AND FILTERS AND TRUCK RAN WELL. AFTER DRIVING ABOUT 2,000 MILES TRUCK WOULD ACT LIKE THE FUEL FILTER WAS CLOGGED. CHANGED THE FILTER AND DID NOT HELP. THEN CHANGED THE LIFT PUMP, STILL NO CHANGE. THEN DUMPED THE FUEL TANK AND GOT ALOT OF DIRT/DEB OUT AND REPLACED A BROKEN PICK UP SCREEN. THIS HELPED BUT TRUCK STILL ACTS UP ABOUT 50% OF THE TIME. WHAT ELSE CAN I DO TO CLEAN THE FUEL SYSTEM?
madeline is offline
post #2 of 6 Old 04-13-2014, 02:43 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
It Might not be your fuel system...could be your injectors...best thing to do is check fuel pressure with the port on the back side of the bowl.
Then, do a buzz test with a good scan tool. If it fails buzz test, then it's your injectors.
Check your high pressure oil pump, look at icp and duty cycle. That will tell you if it's weak
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 6 Old 04-13-2014, 03:26 PM
timmyboy76's Avatar
with all that crap you found, remove the "return" line off thebowl and with light compressed air, clear out the line.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 6 Old 04-13-2014, 05:37 PM Thread Starter
Thanks to both of y'all I will try both ideas. Truck will idle and start normal, only when you start to go between 20 to 40 mph does it start to act like no fuel. If I put it in neutral and rev the motor it will temp fix the problem
madeline is offline
post #5 of 6 Old 04-13-2014, 07:29 PM
timmyboy76's Avatar
do the 50 cent mod.
If planning on keeping ur for awhile, gauges wouldnt be a bad idea....egt, fuel, boost and trans
post #6 of 6 Old 04-13-2014, 08:14 PM
Doesn't Even Care
Quoted: 69 Post(s)
You might can rev the motor, but that's not putting a load in the engine....
Nick
"The Mistress"
