oil blow by into exhaust. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-10-2014, 03:53 PM Thread Starter
I have a 2000 350 7.3 and noticed there was oil in the bottom of the tailpipe. just put a new mbrp 5in stainless exhaust, it has afe intake but nothing other than that. I have asked around some but trying to get an idea of what the problem is and how to check it.
fishaholic86 is offline
post #2 of 6 Old 04-10-2014, 04:21 PM
duck fan's Avatar
Double check your turbo for shaft play. Oil in the exhaust is usually the sign of a dying turbo. Its probably worth pulling the turbo and checking the exhaust housing for oil. A rebuild kit isn't very expensive and its easy to do. especially if you haven't had the wheel contact the housing yet. You may be lucky.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 6 Old 04-10-2014, 04:34 PM Thread Starter
i pulled the turbo checked the wheel on the air intake side and there is no play
in the wheel.
post #4 of 6 Old 04-10-2014, 04:59 PM
timmyboy76's Avatar
only place for oil to enter the exhaust. unless its dumping from an exhaust port and being pushed up through the up-pipes
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 6 Old 04-11-2014, 02:59 PM Thread Starter
I've heard if it has a bad seal it will allow oil to be forced into the exhaust, and intercooler tubes.
post #6 of 6 Old 04-11-2014, 06:58 PM
timmyboy76's Avatar
oil in the IC is from your stock intake set-up...normal for oil to be there, but not normal for oil to be in exhaust tubing.
