High pitched whine - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-10-2014, 12:59 PM Thread Starter
High pitched whine
Not sure where this is going to end up but after searching I did not find much like what I am experiencing. I have an 01 7.3 exursion, on occasion (with no rhyme or reason) I'll get a high pitched whine when I take off, it only happens in first gear and never happens back to back. Any ideas where to start?
macsdaddy is offline
post #2 of 10 Old 04-10-2014, 05:00 PM
timmyboy76's Avatar
can you post a vid?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 10 Old 04-10-2014, 05:17 PM Thread Starter
I'll try but I never know when it's going to happen.
post #4 of 10 Old 04-11-2014, 10:31 AM
timmyboy76's Avatar
check the easy stuff....loose/unconnected boost lines, cac tube boots, remove intake and inspect compressor wheel..black soot on uppipes and/or firewall/
post #5 of 10 Old 04-11-2014, 11:40 AM Thread Starter
Ok doing something different today, the whistle happens through the first acceleration after startup only. I have a video that I'll post when I get in front of a real computer.
post #6 of 10 Old 04-11-2014, 12:29 PM Thread Starter
post #7 of 10 Old 04-11-2014, 01:36 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
Im not a 7.3 expert. BUT sounds like a boost leak or even just normal turbo whistle.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #8 of 10 Old 04-11-2014, 02:05 PM Thread Starter
its not my normal whistle, thinking it may be a leak
post #9 of 10 Old 04-11-2014, 06:57 PM
timmyboy76's Avatar
ya, you can hear the whistle, under the whine. I'd start check'n for soot, loose clamps...if you dont have a set of upgraded cac boots, nows a good time...riffraff has them. them plenum stock boots suck and the clamps they use. get yourself a set of T-clamps and be done along with new boots. To really make a good seal, get the plenum inserts as well...same place.
post #10 of 10 Old 04-12-2014, 02:55 AM Thread Starter
Ok thanks, I'll give those a look.
