diesel in the oil - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-08-2014, 04:50 PM Thread Starter
cocoa2852's Avatar
diesel in the oil
will a hpop pump diesel into the oil I don't know much about diesel but my truck started leaking oil real bad from the side of the oil pan right behind the starter but when I checked it was over full I need some help
cocoa2852 is offline
post #2 of 3 Old 04-08-2014, 05:05 PM
The HPOP is a oil pump and not a fuel pump so no fuel is involved. It will not put fuel in the oil. Your most likely issue is going to be a leaking fuel injector
Dieselinmyblood is offline
post #3 of 3 Old 04-09-2014, 09:08 AM
Yep sounds like some bad injector o-rings maybe?
e3mand is offline
