Coolant blowing out degas - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-07-2014, 02:23 PM Thread Starter
Ok injector cups changed, new o rings on injectors. Filled up degas with water and cranked motor, little rough at first but smoothed out and runs perfect. I ran water in degas bottle with ****pit open for a while. Then closed ****pit and filled with 4 gallons of antifreeze. Been driving it for two days and it runs great but I noticed degas bottle was low so I added to full thinking air worked its way out but now I think its blowing out of the degas cap. No smoke, great power, no coolant in oil, no fuel in coolant. What gives??
Blowing out under boost or load. Is it possible my degas cap is messed up from where the diesel fuel was in the system for a while or did I not get one of the cups seated properly?
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #2 of 6 Old 04-07-2014, 02:37 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
Did you use the cup loctite?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 6 Old 04-07-2014, 02:47 PM Thread Starter
Yes I bought the cups, orings, and injector cup locktite from thoughobread diesel.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #4 of 6 Old 04-07-2014, 02:50 PM Thread Starter
I just checked the coolant level and it was good, drove it out on the highway and really stood on it. Got back and the coolant was to the top of the degas bottle and after a short while in the front yard the coolant level was back to normal.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #5 of 6 Old 04-07-2014, 02:56 PM Thread Starter
Think there is air in the system?
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #6 of 6 Old 04-07-2014, 03:03 PM
LoxDiesel's Avatar
Quoted: 369 Post(s)
Ya its possible. Usually after i reassemble after a tear down I'll let engine idle with the cap off for at least 10 min
@loxdce
