2000 7.3 please help - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-03-2014, 05:51 AM Thread Starter
00 7.3 possible up pipe leaking??
I just had new injectors put in with new uvch and pigtails loop s@b filter and 4 inch diamond eye and ts 6 pos with full custom tunes.. truck runs great.. but at higher rpms I get this noise... would that be my up pipes leaking or turbo going out? There is no shift play in the turbo at all
2000 f350 7.3 - YouTube
bccontract is offline
post #2 of 11 Old 04-03-2014, 11:02 AM
duck fan's Avatar
That sounds like the wheel scraping the housing in your turbo. I would pull the turbo and get a look inside it before you drive it any more. You may have caught it early enough that it hasn't damaged anything else.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 11 Old 04-03-2014, 11:11 AM Thread Starter
I checked the wheel on intake side and it was tight no movement side to side up or down in or out.. just spins freely...
post #4 of 11 Old 04-03-2014, 11:12 AM Thread Starter
I have a few other videos of the nose if you click my name on you tube
post #5 of 11 Old 04-03-2014, 01:08 PM
timmyboy76's Avatar
check the firewall for soot. make sure the red/green lines are hooked to wg and intake tube. all t-clamps tight. try run'n ur in stock setting
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 11 Old 04-03-2014, 03:04 PM Thread Starter
Ya I just replaced all boots on the red and green lines.. they were dry rotted..I haven't had a chance to check firewall for soot yet.. been raining here for 2 days
post #7 of 11 Old 04-04-2014, 08:12 PM
timmyboy76's Avatar
thinking about it, it might be the wastegate opening/closing
post #8 of 11 Old 04-05-2014, 12:17 AM
Rodslinger's B1TCH
it might still be the turbo wheel barely touching the housing at high rpm's. they spin much faster than the rpm's of the engine and it's possible that it is moving/expanding just enough to make a sound.
or maybe it's the wastegate doing funny stuff. what is boost gauge telling you while that is happening?
steve604 is offline
post #9 of 11 Old 04-05-2014, 04:00 AM Thread Starter
Boost Guage stays steady. But before all upgrades was only at 11psi. Now hits like 11psi on all tuned
post #10 of 11 Old 04-05-2014, 06:45 AM
timmyboy76's Avatar
ya, you gotta problem, bud....you should be hit'n 11psi at idle, lol
