7.3L Starter - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-01-2014, 09:20 PM Thread Starter
Exclamation 7.3L Starter
Searched the threads, but could not find info on starter.
I need to replace it, but it looks like there is a two bolt and a three bolt configurations. Without looking at it (since the truck is broken down several miles from here) is there a cutoff on when they went to 2 bolt?
I have a 2002 7.3L SRW Crew Cab 4WD, auto trans with A/C... I THINK that's a two bolt.
Any thoughts?
Generok is offline
post #2 of 12 Old 04-01-2014, 09:26 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Buy the 3 bolt and don't look back
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 12 Old 04-02-2014, 04:38 PM
I like the motorcraft 2 bolt you can pick it up at napa for 180 reman, I know new is new but I have faith in napa parts.
2002 F350 Lariat Super Cab LWB 2WD
My websites:
ascrap2003 is offline
post #4 of 12 Old 04-02-2014, 04:40 PM
carefull with + wire to the starter tightend mine and solenoid broke, add a lock washer, then wire then another washer fixed my problem along with a another solenoid.
My websites:
post #5 of 12 Old 04-02-2014, 04:50 PM
timmyboy76's Avatar
3-bolt here, on a L99. Heard good things about the mitsubishi starters.
timmyboy76 is offline
post #6 of 12 Old 04-02-2014, 05:02 PM
schlutzer's Avatar
Quoted: 18 Post(s)
It doesn't matter if you get a PLGR starter ( Mitsubishi) or OFSR (denso) just make sure you get the high torque version of what you want.
post #7 of 12 Old 04-02-2014, 07:16 PM Thread Starter
Thanks all. It turned out to be a two bolt. While I'm all about getting the best parts I can afford, I'm more about getting the truck back on the road ASAP. Local parts store had a starter in stock, and now my truck runs vs sitting in a parking lot. I appreciate the tips though snd your time to respond. Cheers!
Generok is offline
post #8 of 12 Old 04-02-2014, 08:29 PM
Rodslinger's B1TCH
are the 3 bolt and 2 bolt starters interchangeable?
steve604 is offline
post #9 of 12 Old 04-02-2014, 08:30 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Yes they are.
post #10 of 12 Old 04-02-2014, 09:00 PM
Rodslinger's B1TCH
good to know. if my starter packs it in away from home i can go to the parts store and buy whatever 7.3 powerstroke starter they have in stock.
steve604 is offline
