Help dropped o-ring into the engine - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-31-2014, 06:55 AM Thread Starter
Soooo, I was changing my turbo pedestal o-rings Saturday and when removing the lower ones, the smaller flipped out of the bore and right into the larger and right out of site. I tried to look with a mirror, picture with my camera to see better, fish it out with a grabber thingy, suck it out with vacuum. Finally I looked up that the larger bore should drain to the oil pan. Is this true? Should I worry about it in there? Do I need to drop the pan to get it out? Can I leave it in?
CJC118 is offline
post #2 of 3 Old 03-31-2014, 06:56 AM
That sucks...but it won't pass through the oil pump pick-up screen. Maybe change the oil and if you get lucky the o-ring will end up by the drain hole and you can fish it out.
Dan V is offline
post #3 of 3 Old 05-18-2015, 04:39 AM
hey i was wondering what the outcome with your issue was i did the same thing!
dieseldinosaur is offline
