Stripped starter bolt holes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-30-2014, 02:29 AM Thread Starter
rosshurlow1's Avatar
So leaving work yesterday I noticed my starter sounded weird and then it started to free wheel. I crawled underneath to find the top bolt on the starter was missing and the bottom was barely hanging on. Tightened the bottom bolt an truck started fine. Went to napa and matched the bolt and got two different lengths. Got home to put the bolt in and got it slightly tight but kept spinning. I tried the other bolt was same, kept spinning. I got a tap set at harbor freight what size should I use and any other options to repair? Thanks
rosshurlow1 is offline
post #2 of 4 Old 03-30-2014, 03:56 AM
Harley516's Avatar
Helicoil would be a better method, if you just tap out the hole you will have to go up one size on the bolt, that bigger bolt may not fit through the starter mount hole.
Harley516 is offline
post #3 of 4 Old 03-30-2014, 04:17 AM Thread Starter
Would a auto parts store have that?
post #4 of 4 Old 03-30-2014, 04:21 AM
Harley516's Avatar
Yes, you should be able to pick up a Helicoil at most well stocked auto part stores.
here is youtube video on the procedure. Best of luck to you.
