runs rough - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-29-2014, 11:46 AM Thread Starter
runs rough
I have a 2002 f350 the truck starts real quick and runs good but sometimes the Service Engine Soon light will come on and it starts running on half the motor the drivers side goes dead I have changed the undercover harness and gaskets I have checked the main harness where it plugs in I have swapped injector drivers out when it first started I could turn it off and restart and it was fine but it is getting worse now the HPOP was replaced before this problem started I am not getting any trouble codes either
mack82 is offline
post #2 of 11 Old 03-29-2014, 08:17 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 461 Post(s)
Sounds like you have an injector shorting the bank out. This has happened to me a few times. Only way to tell is unplug one fire it up an see if they stay firing. Go to the next one and repeat.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #3 of 11 Old 03-30-2014, 12:58 AM
Do you have AE? What Ricemiester said...sounds like a wiring issue.
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
post #4 of 11 Old 03-30-2014, 07:56 AM Thread Starter
Yes I do have AE is there's way to check it with ae
mack82 is offline
post #5 of 11 Old 03-30-2014, 08:10 AM Thread Starter
What causes the injectors to short out the wires rubbing together or the soloenoids
mack82 is offline
post #6 of 11 Old 03-30-2014, 12:01 PM Thread Starter
I checked it today with AE and got this in the buzz test
P02070 cyl 4 inj. cicuit low
p0282 cyl 8 inj. circuit low
p1294 inj high side open bank 2
p1296 inj multiple faults bank 2
I replaced the undercover harness on bank 2 with motorcraft parts
mack82 is offline
post #7 of 11 Old 03-30-2014, 04:57 PM
LoxDiesel's Avatar
Quoted: 461 Post(s)
runs rough
No the short im talking about has to do with the coil of the injector internally. Coil shorts out and IDM shuts down left or right bank depending on which side the injector is on. Funny thing is your codes point to the rear injector of each bank. Clear them and do a buzz test.
Sorry didn't read the part about buzz test. Bank 2 is drivers side. Start there
@loxdce
post #8 of 11 Old 03-30-2014, 05:20 PM Thread Starter
I did clear the codes this evening buzz test sounds fine I drove it down the road and it started running bad again I left it running and did a KOER test and soon as test was over it started running on all 8 cylinders again number 8 did come up in this test
mack82 is offline
post #9 of 11 Old 03-30-2014, 05:45 PM
LoxDiesel's Avatar
Quoted: 461 Post(s)
Id say you have your answer.
@loxdce
post #10 of 11 Old 03-30-2014, 06:08 PM Thread Starter
I have a extra set of injectors gonna swap some out and see
mack82 is offline
