hydrolock?? new injector o rings, no crank. - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-25-2014, 06:14 PM Thread Starter
Exclamation hydrolock?? starter problem? new injector o rings, no crank.
I have a early 99 f250 224K
I purchased the truck knowing it needed injector o rings. I did the drivers side o rings no problem had the truck running after I put it back together. Then I did the passengers side which were more of a pain to get back in but I managed. Pulled glow plugs on the side I was working on and blew them out.
Now it will not crank very well, Yesterday I had it blowing some smoke until this happened. Now it cranks a little, starter grinds then pops out and runs free. I pulled the glow plugs on passengers side and still did the same thing. Could the drivers side be locked up some how?? or something else?
video of it cranking:
IMG_2001_zps4020165d.mp4 Video by Michael_Colbridge | Photobucket
Early 99 7.3
MikeyKC is offline
post #2 of 18 Old 03-25-2014, 06:45 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 455 Post(s)
I cant hear your video unfortunately
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #3 of 18 Old 03-25-2014, 07:06 PM Thread Starter
did you have the sound on haha. it works fine on mine when I open the link.
Early 99 7.3
MikeyKC is offline
post #4 of 18 Old 03-26-2014, 12:44 PM
timmyboy76's Avatar
check the hpop level
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 18 Old 03-26-2014, 02:07 PM Thread Starter
It's full . Starter grinds an dosnt want to turn the motor over. I will try pulling all glow plugs and see if it will crank. It cranks for a second then binds up/grinds then starter pops free and runs fast. Had starter removed and tested at orielly it was good.
MikeyKC is offline
post #6 of 18 Old 03-26-2014, 03:58 PM
LoxDiesel's Avatar
Quoted: 455 Post(s)
Maybe its an iphone thing. Ill check later on pc
How many times did you turn it over with the glow plugs out? It takes a few revolutions to blow all the oil/fuel out. Be careful grinding on it to much. You'll bend a rod if theres still oil in it!!!
@loxdce
post #7 of 18 Old 03-26-2014, 06:01 PM
Quoted: 14 Post(s)
Put a breaker bar on the crank and see if you can spin it by hand.
ttyR2 is offline
post #8 of 18 Old 03-26-2014, 06:08 PM Thread Starter
ok, pulled plugs and it turned over fine oil gauge went up rpms moved. did it maybe 3 times about 5 seconds each.
Immediately put in plugs and grinding sound returned without any revolutions like in the beginning of video.
My guess is not enough power to start??- had 13V with multimeter at batteries and they are like 2 weeks old walmart brand. I guess I will bring them in to get checked. I had them on a trickle charger (1.5amp on board battery charger).
Early 99 7.3
MikeyKC is offline
post #9 of 18 Old 03-26-2014, 06:22 PM
Quoted: 5 Post(s)
Sounds like broken tooth or starter disengaging while still turning (solenoid problem)
does not sound hydrolocked.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #10 of 18 Old 03-26-2014, 06:29 PM Thread Starter
I had starter tested was good, it has a lifetime warrantee so it might just "break" some how if batteries test good.
What about the starter relay under the hood do those go bad??
Early 99 7.3
MikeyKC is offline
