Hpop problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-25-2014, 07:25 AM Thread Starter
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Hpop problems
I have a 01 f250, 210k, the hpop was replaced around 20k ago. I believe it was from napa. It has the original ICP and IPR. The problem I'm having is low pressure. I will attach some pics at the end. When it still kinda cold I can hit 3000 psi but when warm I can't get past 2500 psi but is usually around the 2200 mark. First pic is cruse set at 80. Second pic is at wot. Any suggestions in how to fix this would be great.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #2 of 7 Old 03-25-2014, 08:10 AM Thread Starter
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Also has cold start issue
01 f-250, Standard
sbluke55 is offline
post #3 of 7 Old 03-25-2014, 08:19 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
tuned? Inj's? any leaks from the icp? and leaks in general? could be o-rings on inj's could be hpop, buzz test pass? lots could still be going on.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 7 Old 03-25-2014, 08:24 AM Thread Starter
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Yes tuned. I have the hydra on the 100hp setting. ICP is clean. Original injectors but I know my injectors need replaced sometime. Its dirty on top by the spider but I think it is from the boots. Replaced orings on head where the hpop lines connect. I didn't buzz test it. Can you do that from torque.
01 f-250, Standard
sbluke55 is offline
post #5 of 7 Old 03-25-2014, 08:59 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I've herd both ways (I dont have it...yet) about the buzz test. you have a boost guage? if so about is it reading? not part of the cold start but if your lower then normal it could be that....and a hot tune will show a weak/not perfect hpop too, so if it does it on the lower tunes too then it could be an issue.
dannanw is offline
post #6 of 7 Old 03-25-2014, 09:02 AM Thread Starter
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
I don't have s boost gauge but I have it set up in my torque app. I'll out it to stock tonight and see what it does. It sucks because the hpop isn't very old and its the third one.
01 f-250, Standard
sbluke55 is offline
post #7 of 7 Old 03-25-2014, 11:03 AM
layson's Avatar
Quoted: 80 Post(s)
It is hard to tell if your injectors just need some new orings or maybe just need some work. Or it just could be a ****ty pump.
You know sometimes when it is heat related I have seen the coil on the IPR actually shut the truck off when it is warm. That is the little deal that is held on by the little nut on the IPR.
Here are some other good reads...
http://www.swampsdiesel.com/site/how...f/pdf/hpop.pdf
http://www.swampsdiesel.com/files/7....Diagnostic.pdf
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
