Dripping Diesel - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-25-2014, 05:51 AM Thread Starter
Dripping Diesel
New to the this forum. Background info, 1999 Ford with 7.3 powerstroke with on 145K miles, everything original. I haven't ran it much all winter and went to top off the tank before going to pick up a new camper. I left it ideling while filling (I live in SD, still very cold), after paying for #1 diesel, I noticed a puddle of diesel dripping off the front of the motor. Crawling around on a gas stained concrete, I noticed diesel dripping out of what looks like a overflow tube in front of the motor on the passenger side. Next day during start up and ideling (10 degrees) before my trip, noticed another puddle on the gravel. The pickup ran fine when hooked to the camper.
Any ideas, and should I be worried.
kwbaum is offline
post #2 of 4 Old 03-25-2014, 05:57 AM
sbluke55's Avatar
Quoted: 552 Post(s)
Garage
Sounds like fuel bowl drain valve orings. You can rebuild the valve for a few bucks from diesel orings or replace it for around $50
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 4 Old 03-25-2014, 06:22 AM
I have a drain valve on the way with green mil-spec o-rings
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #4 of 4 Old 03-25-2014, 04:16 PM
Quoted: 14 Post(s)
Yep. Fuel bowl drain. Mine did the same thing. New set of nifty O-rings from Diesel-Orings fixed her up.
ttyR2 is offline
