wheres my power loss coming from - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-22-2014, 05:45 PM Thread Starter
I've got an 02 f250 with 350k and it doesn't have the power it used to. I've got a super chip 4" turbo back exhaust s&b intake 10k mod fuel line loop between heads factory injectors and hpop. It has a slight miss only noticeable at idle but otherwise runs great, but there's no low end rpm torque, I only feel power when the rpm are up. I'm trying to figure out if my compression is less than desirable, the hpop is weak or if its a turbo boost loss issue. My thoughts are its not the Turbo because the power I used to have as soon as you lunch the throttle wouldn't be from boost cuz it hadn't built up yet. I get 23 psi boost when I'm on it hard so I know the turbos doing the job. My 10k mod I have an on off switch and you can seean instant change so iI think my hpop is good, I haven't had the weekend off to check the compression so Idk about that. Any help would be great
rffpsvb is offline
post #2 of 13 Old 03-22-2014, 07:53 PM
Quoted: 759 Post(s)
You change your fuel filter lately?
Corey@CNCFAB is offline
post #3 of 13 Old 03-22-2014, 08:06 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 54 Post(s)
Feedback Score: 7 reviews
Hpop might be wore out
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #4 of 13 Old 03-23-2014, 06:02 AM Thread Starter
ive changed the filter and seen no significant change in low rpm power, some improvement in acceleration once rpms are up. How do I check my hpop to see if its producing adequate pressure? I made up a gauge to tap into the icp port so I can read the psi but im not sure the parameters of whats normal and whats low
rffpsvb is offline
post #5 of 13 Old 03-23-2014, 06:32 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 347 Post(s)
I hope its a 5000 psi gauge with a high pressure hose. When cranking it should go up to around 2600 psi IIRC. cold at an idle it should be around 800 psi.
I have a truck thats doing this in a fleet that i maintain but i haven't gotten around to diagnosing it yet. Honestly I don't believe its your pump, the truck i'm talking about has a brand new ford reman in it.
One thing to check. The hose for your map sensor. Have you replaced it? Is it cracked up/old? I know without a map value it will act that way.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #6 of 13 Old 03-23-2014, 08:08 AM
Codum's Avatar
I had the same issue and I chase it for a year. I finally replaced injectors and problem solved. My guess is you have a bad injector. My buzz test was fine, but like you, no low end tourqe. Ran fine at higher RPMs. Good luck!
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #7 of 13 Old 03-23-2014, 08:26 AM Thread Starter
When you say you have a ford reman are you talking about your hpop or the complete engine? Yes its a 5k gauge with appropriate hose, I used it for diagnosing my dads IPR problem so I know it works. My buzz test and contribution test checks out so I don't think its a injector, it runs fine at low rpm bit when you jam down on the throttle at idle you don't see power until the rpms get up then she takes off. I haven't checked my map hose in a while but my boost gauge Ts off of it and I have normal boost so I don't think its that
rffpsvb is offline
post #8 of 13 Old 03-23-2014, 08:38 AM
Codum's Avatar
My transmission is a ford remanufactered unit. My engine is original except for the injectors. You are describing exactly what my truck was doing. There is no way to test the mechanical side of a 7.3 injector while it's in the engine. You are only testing the electrical side. I bet you have one or more injectors that are not working mechanical at there peak. They may be putting out some fuel but not at specification. You could pull them all send them off to be tested mechanically them replace the ones that are not up to specification, but with 350k I would replace them all. While your under the valve covers you need to put in need glow plugs and UVCH. (unless you already have). I went with the swamps due tithe 250k warranty. Total cost performing the work myself was $1,500. Good luck!
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
post #9 of 13 Old 03-23-2014, 08:59 AM
LoxDiesel's Avatar
Quoted: 347 Post(s)
Reman ford engine complete
@loxdce
post #10 of 13 Old 03-23-2014, 09:12 AM
Codum's Avatar
When cranking it needs 500psi. If its really cold my idles at 750-800 as it warms up it will drop to 475-500. The max you see is 3000 psi under load at full throttle. This of course is on a stock truck.
DIY 6637
Warn Premium Hubs
"We Farm for Ducks"
Stock 225k miles
Codum is offline
