7.3 SES light Under load and loss of a Bank - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-22-2014, 09:19 AM Thread Starter
Alright well for the past week my 2001 Every once and a while Throw a SES light and lose a bank and everything would be fine if i shut the truck off and turn it back on. Then the other day it wouldnt stop doing it. My buddy has a Actron CP9180 and he couldnt pull any codes from it..... He has pulled codes from a 08 6.4 powerstroke with this reader. I pulled off the valve covers hoping the UVCH was just coming unplugged and neither side appeared to be unplugged but i pushed them together anyways and then fired the truck up and now cant replicate the problem. Anybody have any ideas? or any test i can do to see if its somthing else while i have the valve covers off.
2001 Ford ECSB F250
5in turbo back exhuast
AEM Intake
Foil Delete
Glowshift Gauges
PHP Pheonix
JMOEL4 is offline
post #2 of 3 Old 03-22-2014, 10:31 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Forget the Actron, if your light came there IS a code, you just need better equipment to get it.
Maybe you actually fixed it when you unpluged-plugged the UVCH connectors (I would do the "50-cent mod before I closed them up though). If the pins look good (you looked Really carefully - right?) and it does it again, I'd suspect the IDM....
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
JMOEL4 (03-22-2014)
post #3 of 3 Old 03-22-2014, 12:30 PM Thread Starter
Ya i checked the pins and they looked good thanks for the help and now its time to pull the turbo cause i found my oil leak which it is coming from between the turbo and the pedestal...... time for some more fun
2001 Ford ECSB F250
AEM Intake
Foil Delete
Glowshift Gauges
PHP Pheonix
JMOEL4 is offline
