7.3 no start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-21-2014, 10:54 AM Thread Starter
7.3 no start
2000 f250, 7.3, auto.
First of all I had swamps 250/200's installed, 2k miles later and I loose a nozzle. Swamps replace free of charge and even ships back free. I shipped all 8 injectors off for testing just in case of another failure. After installation I cant get it started.
HPOP if full of oil
2 new battery's as of yesterday
I get 'wait to start' light
I get RPM gauge movement on cranking
Fuses checked
I have cranked for 3 days on it and not even a hit.
The ONLY problem on installation was that I turned key on "priming system" with the battery on the pass. side with only one terminal hooked up. I saw a little smoke outta the hood and immediately turned the key off to see the problem. I dont see anything melted or looks like it got hot but something did.
Any suggestions? Im lost.
Very much appreciated any and all help.
wiley79 is offline
post #2 of 6 Old 03-21-2014, 12:39 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
I'm thinking fusible link blew somewhere. You have to find where the smoke came from.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 6 Old 03-21-2014, 12:56 PM Thread Starter
where are the links located? Thanks
2000 f250 crew cab, 7.3 auto, 250/200cc hybrids from Swamps, Swamps tunes, 38r turbo, ARP head studs, Comp springs, Riffraff boots, cold air, 5 inch exhaust, 3 inch lift.
wiley79 is offline
post #4 of 6 Old 03-21-2014, 04:32 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
I believe one on each fender well behind the battery's. You need to find where the smoke came from first.
01 f-250, Standard
sbluke55 is offline
post #5 of 6 Old 03-21-2014, 05:09 PM Thread Starter
Got it started, ran it about 30min then drove it up the road for 1 mile and she lost all oil pressure. Possible overhaul or HPOP, dont know yet.
wiley79 is offline
post #6 of 6 Old 03-21-2014, 07:50 PM
Quoted: 818 Post(s)
Gonna say from reinstalling your sticks you got a piece of dirt/debris stuck in your ipr and its stuck dumping all oil back to the pan. Take it apart and clean it.
Corey@CNCFAB is offline
