Cutout/miss - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-19-2014, 08:10 AM Thread Starter
02PSDWV's Avatar
Send a message via AIM to 02PSDWV
Cutout/miss
Alright. Let's start off with the truck is a 2000 7.3 6 spd 208,xxx on the clock. My problem happens generally on take off or going up hills. The truck will cut out then it acts like it goes into limp mode. Turn it off and right back on and it runs fine. Only does it every once in a while. I just changed fuel filter. Could it be a pickup problem in the tank? I can't get the truck to do it when I'm near a place to throw it on a computer and see if any codes are coming up(the check engine light is on already because of an abs problem). It seems like a fuel problem to me but I hate to just start throwing new parts at it.
02 F-350 PSD 4.56's 37" SSR's
96 Ranger 532C.I. BBF 2.5 tons 4-link w/14" FOA's 44" Boggers
93 F-350 41" IROK's
92 F-150
79 F-350 R.I.P.
78 Bronco
02PSDWV is offline
post #2 of 7 Old 03-19-2014, 08:26 AM Thread Starter
02PSDWV's Avatar
I should add that I've put it on a computer a few times after the problem has happened and no codes show up. Also the truck has no starting issues.
93 F-350 41" IROK's
92 F-150
79 F-350 R.I.P.
78 Bronco
02PSDWV is offline
post #3 of 7 Old 03-19-2014, 09:58 AM
schlutzer's Avatar
Quoted: 18 Post(s)
How much boost are you building before this happens? It sounds like you are de fueling to me
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 7 Old 03-20-2014, 01:55 PM Thread Starter
02PSDWV's Avatar
My turbo is taking a dump on me, it will only build 8-10 psi boost. I'm trying to find a turbo now but idk if that would be a related problem or not. To me it really feels like its in limp mode or something, I mean it falls completely on its face and will barely pulls itself and you can tell its only running on a couple cylinders. Sometimes there will just be a short miss every once in a while and it'll keep running fine. I generally do all my own mechanic work but this one has me stumped, I just hate to take it to a shop or start throwing new parts on it. I've tossed the bad pickup idea around but it does it even with a full tank.
93 F-350 41" IROK's
92 F-150
79 F-350 R.I.P.
78 Bronco
02PSDWV is offline
post #5 of 7 Old 03-23-2014, 03:18 PM
Defueling?
2002 F350 Lariat Super Cab LWB 2WD
My websites:
ascrap2003 is offline
post #6 of 7 Old 03-23-2014, 04:26 PM
Codum's Avatar
If its running on a few cylinders it would be running ruff. Limp mode and ruff are two different things. If I were to throw parts based on what you have said it would b a ICP then UVCH.
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #7 of 7 Old 03-23-2014, 04:33 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You need to datalog.
Get something android compatible with the torque app and buy the connector then monitor it. Otherwise you're just going to piss money away until you get lucky
