Injector o rings help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-16-2014, 08:47 PM Thread Starter
Redrock2000's Avatar
Quoted: 2 Post(s)
Put new Alliant o rings in my truck this weekend. Barred the engine over to blow out the cylinders. Cranked and cranked finally started and ran rough as I expected. Smoked grey at first and cleared up. I couldn't take it for a drive to purge the air from the system and it wouldn't idle. Went to start it again and it won't start. Cranked the batteries dead charged the cranked them dead again not even a buck from the engine trying to start. I guess from what I've read I just keep cranking it? Why did it start earlier and not now? Please help
I don't care how they do it in Japan
Redrock2000 is offline
post #2 of 7 Old 03-16-2014, 10:19 PM
Once it starts it will stay running.
Do you have AE or something similar?
Check engine oil level and fuses in engine bay.
Make sure both injector/glow plug harnesses are plugged in at valve covers.
Are you positive the UVCH's are not loose? 50 cent mod?
42 pin connector at d/s valve cover tight?
HPOP res full?
It's really nice to have AE for stuff like this.
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
post #3 of 7 Old 03-17-2014, 03:22 PM
duck fan's Avatar
Without a way to monitor what the PCM is seeing and doing, you are going to chase your tail on this. Do you have a scanner of some sort or access to one?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #4 of 7 Old 03-17-2014, 03:48 PM Thread Starter
Quoted: 2 Post(s)
Unfortunately all I've access to right now is my torque pro app. Thanks for the replies I'll look for the obvious for right now and go from there.
post #5 of 7 Old 03-17-2014, 05:00 PM
duck fan's Avatar
With your Torque Pro app, are you seeing any codes stored in the PCM?
duck fan is offline
post #6 of 7 Old 03-20-2014, 03:53 PM Thread Starter
Quoted: 2 Post(s)
No codes but wonder about the torque app since I've had intermittent ses lights before the o rings. Top off the hpop now I guess I'll just keep recharging the batts and crank it. Thanks for the replies
post #7 of 7 Old 03-23-2014, 01:18 PM Thread Starter
Quoted: 2 Post(s)
Finally got it running now it smokes white/grey runs ok not much different guess I'll just keep trying to get injectors. I wanted to go larger but I'm more concerned with reliability now so maybe I'll get a couple of stock rebuilds at a time
