Borg Warner cps stall - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-11-2014, 01:04 PM Thread Starter
rosshurlow1's Avatar
Thumbs up Borg Warner cps stall
So I put the new cps in from advance auto and test drove it last night. Seemed to smooth things out. I go to let my truck warm up this mourning and it misses then dies. Starts back up then dies. My icp sensor is leaking out the plug but works fine with the ford cps. Could it just be the sensor
rosshurlow1 is offline
post #2 of 4 Old 03-12-2014, 09:01 AM
duck fan's Avatar
Oil in the ICP plug can cause all sorts of issues. You absolutely need to get that replaced
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 4 Old 03-16-2014, 06:09 AM
delta99's Avatar
unplug the icp sensor and see if it idles better and stays running. If not, you have another issue, but that sensor definitely needs replaced. Mine was starting to leak oil, but the truck was still running fine. I replaced it right away anyways, before I did have issues
1996 F250, 7.3L, auto trans, 4x4, eclb, TS Performance 6 position chip
delta99 is offline
post #4 of 4 Old 03-16-2014, 07:59 AM
blue99stroker's Avatar
Quoted: 283 Post(s)
be careful with the borg warner cps and your wipers.
mine would die with the wipers on.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
