Long starts,dies, HPOP level going down - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-10-2014, 06:29 PM Thread Starter
Hoping for some help here Powerstrokers... My truck. 1999.5 F350 96,000 miles. New injector O rings (alliant),new ICP, glow plugs, Big relay (stancor), new water pump, turbo housing(cured surge), S and B intake. Always had long starts 4-5 secs, Hence the new O rings that I hoped would cure. Good fuel pressure, HPOP had excellent pressure (>2600psi) by hose and gauge I made up. In other words I have checked and checked. Oh ya, no gray or blue smoke. Yes I have put it on a computer, but did not have a print out to tell you numbers. If I remember it kept giving us a low ICP code???? But, it fired near 500.
Ok my new problem. parked the 5th wheel the other day and had to readjust. Truck started then died. Started right back up and ran fine. Kinda tried to blow it off, but then it did it again 3 days later. level ground. Oil psi gauge does not come up till it starts + a couple secs. Mind you its 70 degrees today. Everything seems to point towards LPOP, but my HPOP level is creeping down already today after 4hrs, its about 3/4" down. It was 3/8" initially. Ideas?? check valve in the HPOP? I know its low mileage for this, but I am out of ideas??
Thanks in advance.
John
gacnik123 is offline
post #2 of 10 Old 03-11-2014, 07:46 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
You lost 3/8" after 4 hours? That's not really enough to make a difference, an inch low is considered normal.
Thermal expansion alone might explain it, I'd consider it important if you found it 3-4 Inches down overnight. Put a mechanical gauge on and read the EOP accurately so you know what's going on if you're concerned.
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
gacnik123 (03-11-2014)
post #3 of 10 Old 03-11-2014, 02:51 PM Thread Starter
Put a gauge on the top of the HPOP today at operating temp and it ran about 38psi. Jody at DP said thats about what his runs. That was at idle. We also put it on a computer and everything seemed ok. P0476 was the only code. Oil stayed about the same overnight in the HPOP res.. I ran a fuel psi test one time last yr and everything seemed high, but I am beginning to wonder about that. I notice this issue happening once the fuel gets lower than 1/4 tank. I know about all the info with the tank mods, Hutch, and almost wonder if aeriated fuel may be causing something. I am guessing now, but it needs done any way..Also, I am going to switch from 5w-40 back to 15w-40. Put in a new CPS after getting home today also. Parked on a pretty good incline today and it fired up. Anyway this was todays checks. Thank you for your reply. John
post #4 of 10 Old 03-12-2014, 10:00 AM
duck fan's Avatar
Miles are pretty low for an LPOP problem too. Your symptoms certainly point that way but most of the LPOP failures we've seen have been >200K miles. When you measured pressure, was that on a cold start?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #5 of 10 Old 03-12-2014, 10:35 AM Thread Starter
Truck was at operating temp after 2 hrs driving. Cold starts are no issue. Fires right up even after 2-3 days sitting. Oh ya with very little rpm increase psi came up very solid
post #6 of 10 Old 03-12-2014, 01:48 PM
duck fan's Avatar
So what are conditions like when you have your start and die issue?
duck fan is offline
post #7 of 10 Old 03-12-2014, 02:38 PM Thread Starter
Its happened twice in 2 weeks. first time parked the fith wheel-had to readjust so jumped in the truck 2 minutes after shutting off. Truck started and just shut off. key off and tried again and she fired right up like nothing ever happened. OAT was freaking cold, but i had just pulled about 15 miles or so. Truck was plenty warm. 2nd time wife came home parked it outside. I went out about an 1/2hr later to put it in the garage and bingo. Ditto to the above mentioned. Both farely level ground.
post #8 of 10 Old 03-12-2014, 02:42 PM Thread Starter
I was on the phone with Justin at DP when we had it hooked up to the scanner and he thought it sounded like a CPS. For the price I picked one up and installed it when I got home. I haven't driven it much since the install. The one I took out was light gray just like the one I put in. Hopefully!!!
post #9 of 10 Old 03-12-2014, 09:48 PM
duck fan's Avatar
That was going to be the next thing I was going to suggest. Hardest thing about random issues is that its hard to know when its really fixed
duck fan is offline
post #10 of 10 Old 03-15-2014, 07:09 AM Thread Starter
So far new cps seems to be working.. I will keep driving with fingers crossed. Going to change o rings on the ipr this weekend. Thanks again!!
