no trailer plug turn signals? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-08-2014, 06:05 PM Thread Starter
rosshurlow1's Avatar
I switched around those relays under the hood and didn't notice any difference in the prongs. Im getting only 1-2 volts on the turn signals/brake light, and 12 volts on running lights and brake. I checked my ground and it looks ok. and how can I test those relays by the air cleaner?
rosshurlow1 is offline
post #2 of 3 Old 03-10-2014, 03:08 AM
pororke79's Avatar
You can test relays by using a 9 volt battery to supply the relay coil after removing the relay from the truck. Use an ohmmeter to check the contact resistance. Resistance needs to be less than 1 ohm. Have you check the backside of your trailer plug? Most of my trailer lighting problems come up there. The connections corrode and cause all kinds of issues.
pororke79 is offline
post #3 of 3 Old 03-10-2014, 03:15 AM
pororke79's Avatar
I used a friends truck last year that had this issue, his had a round plug about 10" in front of the trailer plug that was bad. Took it out and soldered the wires together and then shirk wrapped them. Worked good after that.
