Acceleration hesitation and rattle - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-05-2014, 03:52 PM Thread Starter
Have an E99 dually with a 120,000 miles on it. I installed an edge evo ht programmer. During a hard acceleration the truck has a rattle like its running out of fuel. If I lift my foot a little the rattle will go away and the engine will catch up. The truck only does this on the 80 & 100 HP settings. It seems to run perfectly on the lower settings and in stock mode. I didn't think a simple programmer would require more than stock fuel flow? The truck starts to pull hard then just kind lays down until I lift my foot. If I try to accelerate slow it's no problem but fast an under load it just sounds like a Diesel engine running out of fuel. I'm not super familiar with powerstrokes and could use a lil direction! Thanks for any input!
99Superdually is offline
post #2 of 2 Old 03-05-2014, 04:08 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Possibly hitting boost level, but probably running out of fuel OR high pressure oil.
Only way to tell is with a gauges/data.
4R100, 2wd
330,000 + miles
jesilvas is offline
Tags
7.3 , hesitation , rattle
