Possible hpop problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-04-2014, 09:23 PM Thread Starter
USMC
Dorow's Avatar
Ok so without going into to much detail. 2000 F-250 it's my buddy's truck and I'm stumped
No oil getting to injectors and the reservoir level is fine.
Is there any way the hpop is not pumping oil.
I need as much help on this I can get
If you need more details just ask
2007
Ford F-250 Powerstroke
TS Livewire
Straight Pipe
Blackout
More To Come Soon
Dorow is offline
post #2 of 7 Old 03-04-2014, 10:03 PM
Do you have the valve covers off? How do you know the injectors aren't getting oil?
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
post #3 of 7 Old 03-05-2014, 06:59 AM Thread Starter
USMC
Dorow's Avatar
Valve covers are off and when turning over the motor no oils is coming from the injectors
2007
TS Livewire
Straight Pipe
Blackout
More To Come Soon
Dorow is offline
post #4 of 7 Old 03-05-2014, 09:36 AM
Might be stupid but is their enough oil in the pan? Any ICP when cranking? Can you confirm hpop res is getting oil...if you pull res plug and crank it will be a huge geyser, oh how I know this.
post #5 of 7 Old 03-06-2014, 03:37 PM Thread Starter
USMC
Dorow's Avatar
Just replaced the oils and levels are good. Haven't pulled the plug on the hpop resivor but I'll try that out Friday. My shops closed till then. Any more input would be greatly appreciated
2007
TS Livewire
Straight Pipe
Blackout
More To Come Soon
Dorow is offline
post #6 of 7 Old 03-06-2014, 07:41 PM
Here is something to look at that might give you some ideas. I hope it's OK to link another site for this.
http://www.dieselequipment.com/files...HPOP-Guide.pdf
My truck would have a "no start" from time to time and when I was able to measure it the output of the HPOP would only be around 180# and it needs to be 500# to allow the truck to start. The IPR was sometimes hanging open and bleeding off my pressure.
bob98247 is offline
post #7 of 7 Old 03-07-2014, 10:26 AM Thread Starter
USMC
Dorow's Avatar
Thanks for the IPR info. I read into it and I'm going to take it apart and clean if today to see if that's the culprit.
2007
TS Livewire
Straight Pipe
Blackout
More To Come Soon
Dorow is offline
