00 7.3 slow cranking - PLEASE HELP!! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-04-2014, 01:39 PM Thread Starter
Have a 00 7.3. Recently just changed gpr and all gp. One battery was bad replaced that with a new battery and other battery was still good.
Whenever I go to start the truck and gp come on you can watch the battery gauge drop down to around 8 volts. Soon as glow plugs shut off it comes back up to the right reading on gauge. Go to crank it and it cranks very slow and can watch the battery gauge drop again and it will not crank over fast enough and basically just sounds like batteries are dead.
Plug the truck in for a little bit and it will start right up without the gp's.
What could be causing this? Bad starter or possibly batteries weak again?
The one battery is a few weeks old and the other one that I didn't replaced is a little over a year old. Also weather has been in single digits over night but whenever I tried starting today it was probably around 35 and still did the same thing.
Should I pull the batteries out and go have them tested or would it be the starter getting weak or possibly some other issue?
Please help!
PaDC5 is offline
post #2 of 19 Old 03-04-2014, 03:40 PM
duck fan's Avatar
Most likely its the batteries. They should always be replaced in pairs as when one goes, the other usually follows as its been making up for the dying one.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 19 Old 03-04-2014, 03:53 PM Thread Starter
That's what I kind of figured. I'll probably pull out the batteries tomorrow and take them to advance and get them replaced. Both are still under warranty for free replacement.
Still don't really understand why it would crank over with being plugged in but I guess it kind of makes sense since the glow plugs won't be on to draw power.
Also I have my gpr wired to a switch in cab so I control that. As soon as I turn the switch on you can watch the battery meter drain.
PaDC5 is offline
post #4 of 19 Old 03-04-2014, 07:56 PM
pororke79's Avatar
I don't know what your skill level is but 12 volts on a digital volt meter indicates a dead battery. I deal with this on an almost daily basis in the winter. A good battery will have around 12.6-12.8 volts. I agree both batteries should be replaced together. Make sure all your connections are in good condition also.
pororke79 is offline
post #5 of 19 Old 03-04-2014, 07:59 PM Thread Starter
I have good mechanical skill. I have done all the work on this truck such as glow plugs, relay, etc and I've done all the work on a previous Cummins I have owned as well as all myotber vehicles. Unfortunately I do not have a multimeter. May have to go purchase one or just bring them to advance and see what happens.
I knew batteries should have been changed together but was hoping to get away with it for the time being. But the weather going down to the single digits lately around here didn't help out much.
PaDC5 is offline
post #6 of 19 Old 03-04-2014, 08:00 PM Thread Starter
Prior to all of this the truck seemed to crank over fine to me tho, but I am new to all of this powerstroke stuff. Will eventually be doing a 12valbe swap
On this truck but would like to get it running reliable for the time being.
PaDC5 is offline
post #7 of 19 Old 03-05-2014, 02:54 PM Thread Starter
Ok so I got 2 new batteries. Truck cranks fine. Build oil pressure whenever cranking and acts like it wants to start. RPMs do jump up but it just will not turn over. What coukd this problem be? Truck hasn't ran for a few days and it is currently 26 degrees here.
Could it just be the colder weather and need plugged in or other issues? There is no smoke or anything coming from the truck whenever cranking.
It is supposed to warm up to 50s on Friday so I will try a cold start again on that day.
If truck is plugged in for a couple hours it will turn right over without any hesitation or without assistance of the gp's.
Glow plugs are new motor craft glow plugs and the relay has been replace and tested and tested fine.
PaDC5 is offline
post #8 of 19 Old 03-05-2014, 03:16 PM Thread Starter
Also truck is completely stock. And whenever swapping glow plugs I also put on new valve cover gaskets. The wiring on the connectors for the valve covers seemed fine intact and in good shape so didn't change those out.
PaDC5 is offline
post #9 of 19 Old 03-05-2014, 03:56 PM Thread Starter
Also truck does have 15w40 oil in it. Was thinking about changing it to 5w40 synthetic snd see if that helps. Read tbat makes a huge difference for cold starting in colder weather. Not sure if it would be worth it?
PaDC5 is offline
post #10 of 19 Old 03-06-2014, 02:27 PM
duck fan's Avatar
Any way to monitor ICP and duty cycle while cranking?
duck fan is offline
