Low boost, high get, way too much fuel please help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-03-2014, 06:10 PM Thread Starter
Okay I have a 7.3 psd in a 00 ex mods are as follows, 38r ww2, farmers single shot 165/100's, t500, swamps module, 4-5" exhaust, ebpv delete, hydra custom burnt chip, intake, snow perf stg 3 water meth, i think thats it i cant remember for sure. Heres the problem yesterday I was on it hard all was working well then boost just plummeted I am making 13lbs at redline and bellowing black.
Ive checked the following map, turbo, pressurized the charge side no leaks, wastegate isn't stuck open, everything seems to be in order i just have no boost.
Any help would be great thank you!!!
slc4me is offline
post #2 of 9 Old 03-03-2014, 06:56 PM
Macon's Avatar
Leaking up pipes.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 9 Old 03-03-2014, 06:59 PM Thread Starter
I checked them and didnt notice any excess soot i would that be present?
slc4me is offline
post #4 of 9 Old 03-03-2014, 07:04 PM
Macon's Avatar
That would be present. Pop your hood, and throttle up in gear, with your foot on the brake. Don't roast your tires, just try to build boost. If there's a leak pre-turbo, the smoke will rat it out.
Unless there's a hole in one of your boots, I'm unsure.
2002 F250 CCSB 4x4
Macon is offline
post #5 of 9 Old 03-03-2014, 07:17 PM Thread Starter
Its dark now i will try in the morning. I capped the turbo inlet and pressurized the system from the map sensor inlet on the intake manifold it didn't show signs of a leak.
slc4me is offline
post #6 of 9 Old 03-05-2014, 03:16 PM
Quoted: 782 Post(s)
Sounds like you have an injectors stuck open on the fuel side.
Corey@CNCFAB is offline
post #7 of 9 Old 03-05-2014, 04:12 PM
Macon's Avatar
That would cause a dump in boost?
2002 F250 CCSB 4x4
Macon is offline
post #8 of 9 Old 03-05-2014, 04:27 PM
Quoted: 782 Post(s)
Yes. My truck did the same thing when I was running 160/100's and had the oil side stick open. Being the oil side I bellowed white smoke though. Fuel side would be rollin coal.
Over fuel will cause drag on the turbine wheel.
post #9 of 9 Old 03-05-2014, 04:56 PM
Macon's Avatar
And I learned another something. Thank you for the insight.
2002 F250 CCSB 4x4
Macon is offline
