Hard Start.... Need Help.... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-02-2014, 11:18 PM Thread Starter
I just got a 00 F250 w/7.3 and I have some questions. Im having a hard time starting it after sitting more than 12hrs. I can plug it in for about 3hrs and it will start. New batts, new batt cables, new GPR, new air intake temp sensor on air box and manifold, fresh filter change. I have tested the GPR connections...all good. I have a light hooked up to GPR to show me when the glow plugs are getting power. Comes on about 1 out of 4..Have new reduction gear starter, new glow plugs, new alliant O-rings, and new cam position sensor on the way. Could it be the glow plug controller, oil pressure sensor, water temp sensor, or???? Need alittle help..
dangerdon is offline
post #2 of 3 Old 03-03-2014, 04:01 AM
E99F350Stroker's Avatar
How many miles are on your truck? If it is high mileage, or even if it hasn't been maintained the injectors could be just flat worn out. That can cause cold start issues.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #3 of 3 Old 03-03-2014, 06:41 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Have you checked the plugs themselves or is that what you meant by "I have tested the GPR connections" ? (GPR is the Relay).
And what does (the GPR) "Comes on about 1 out of 4" mean?
3/4s of the time the relay doesn't come on when cold?
I assume you're read this ->Troubleshooting GPR & GP's
NoRalPh is offline
Tags
cold start , glow plug control module , gpr , no start
