$3800 Repair.......and counting. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-02-2014, 07:24 PM Thread Starter
I am new to this forum and need some knowledge and advice. I am NOT a mechanic or that mechanically inclined. I have just a general understanding of how diesels work so please be gentle.
I have a 2001 F250 4X4 Crew cab. I bought it used ten years ago and it has 157,000 miles on it. All I have ever had to do to it is oil changes and brakes. It has been an outstanding truck. Last week it started spewing fuel. I had it towed to a diesel shop. On inspection, they found that the up pipes were leaking badly, the intercooler hoses were bad and a bad fuel line (obviously). I was quoted a price of around $2200 to repair. while in the shop, it was discovered that the turbo pedestal needed to be replaced as well, due to the plunger leaking. I also had a new air filter, fuel filter and oil change. The total was $3800. I was shocked but paid it because I love this truck. However, the truck is now running worse than when I took it in (minus the fuel leak of course).
When idling, there is a shaking that feels like the engine is loose from its mounts and there is an oil leak. But the worst part is the complete lack of power. It takes about a mile to get up to 45 MPH and the hissing from the tail pipe when the vehicle is accelerating is incredibly loud. Also, it doesn't shift correctly anymore. As I accelerate, if I stay on the accelerator, just before it hard shifts to third, there is a cloud of black smoke. The smoke stops as soon as it shifts.
The shop wants me to bring it back in and they think its the turbo unit. If so, they said that the part alone is $2000. I am tapped out with the $3800 as I am a disabled veteran on a tight fixed income. I am really disappointed to spend so much and get back a truck in worse condition than when I left it. Any ideas or help would be appreciated.
Lurch242 is offline
post #2 of 13 Old 03-02-2014, 07:42 PM
Quoted: 724 Post(s)
Check the plugs that go into the valve covers. Sounds like your only running on 4cylinders due one of them not plugged in all the way.
The hissing is your turbo pedestal actually working correctly.
$3800 is retardely expensive. Should've been closer to $1000 total. Only that high due to labor and the up pipes and turbo can be a royal PITA to get apart for the first time in 10yrs.
Corey@CNCFAB is offline
post #3 of 13 Old 03-03-2014, 01:31 PM Thread Starter
Thanks for the advice! The plugs are firmly seated and all connections are good. Any other ideas?
Lurch242 is offline
post #4 of 13 Old 03-03-2014, 08:42 PM
Quoted: 724 Post(s)
Unplug one of them and see if it runs the same. Then plug it back in and do the same thing g to the other side.
Also check your ICP sensor. Refer to the link below.
Unplug it to see if you have oil in the plug. If so, its bad or going to be bad soon.
http://i.imm.io/4AYi.jpeg
post #5 of 13 Old 03-03-2014, 09:22 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
is the ebpv staying closed?
if the ebpv is staying closed while you try and accelerate its not gonna have any get up and go.
check and see if they hooked up the ebpv rod.
i bet they forget to hook it back into the linkage on the turbo.
and i think checking your icp or ipr isnt a bad idea either like hucroey said.
blue99stroker is offline
post #6 of 13 Old 03-03-2014, 09:29 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
they way way way over charged you. sorry to hear :/ i wouldnt return to them.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #7 of 13 Old 03-03-2014, 09:34 PM
This is most likely your problem as it will give you no power, funky shifts and smoke.
01 RC/LB, BD Trans, 38R, 238/80, Hydra/Gearhead, RR/Fuel Lab, Adrenaline
Greenman01 is offline
post #8 of 13 Old 03-03-2014, 09:35 PM
Quoted: 244 Post(s)
oh and thank you for your service!
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
post #9 of 13 Old 03-04-2014, 12:41 AM
Rodslinger's B1TCH
the shop is screwing you. cut your losses and find another shop. i hate to say it, but i think the shop you went to saw a disabled veteran come in and they're pulling a classic scam on you.
they did $3800 worth of minor work and let you drive it away nearly undriveable. then you call them about it and they diagnose your problem over the phone as needing a new turbo right after they removed the turbo? that is absolute BS
try to find a reputable shop, maybe post up your location so someone on here can recommend a shop. take your truck to that shop along with your invoice from the other shop. ask them to check to verify that they actually replaced the parts that they did and check to see what your current issues are. if all else fails, take it to a ford dealer.
i wouldn't doubt that they sabotaged something so you would have to come back. it could be something as simple as the wastegate jammed on the ebp valve. i had this happen to me when i installed my billet turbo wheel.
steve604 is offline
post #10 of 13 Old 03-04-2014, 01:07 AM Thread Starter
Thank you all for the info and suggestions. I will look at the truck tomorrow. Can someone give me an idea of where to look to check the ebpv rod?
Lurch242 is offline
