How hard to replace injectors? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-02-2014, 07:43 AM Thread Starter
rosshurlow1's Avatar
going to replace injectors with swamps stage 1 and glow plugs while Im at it. My truck came from texas so I doubt the previous owner ever touched the glowplugs. I keep hearing scary stories at old glow plugs breaking off in the head. The Injector changing seems a little complicated too. Im mechanically inclined but would you have a diesel shop do it that has experience?
rosshurlow1 is offline
post #2 of 8 Old 03-02-2014, 08:06 AM
Colin7.3's Avatar
i have done my injectors and glow plugs multiple times. my truck has 344,000 miles on it and the glow plugs came out just fine, even for being autolites. i replaced them with dieselRX plugs.
i can have injectors out, back in, and truck running in 3 hours start to finish
itd not a hard job at all. if its your first time, take it slow and remember how everything comes apart and goes back together
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 8 Old 03-02-2014, 08:22 AM
alaskan155's Avatar
Quoted: 65 Post(s)
there pretty easy just take your time,
might want to pressure test the cooling system while they are out and inspect the injectors cups.
as for the glow plugs if you have autolites they can be dis-formed, i had them in for 10k miles and all came out except cylinder one, i had to start the engine to pop it out.
i bought mine last year with 116k and diesel in the coolant an never worked on them before, (played a gamble but it was the truck i really wanted it) and had to pull the injector cups out and reseal the injectors, there are a few videos on youtube on how to do it if your worried but basically you pull the inter-cooler pipes/intake, unplug map sensor, and remove the valve covers(a 1/4 inch swivel and extensions will help big time here), then everything is accessible, just pull the drain plugs on the fuel rail(Allen key) and pull the injectors and plugs.
on reassemble leave the glow plugs out and engine harness unhook and set the valve covers back on with 1 bolt and turn the engine over to clear the cylinders of oil, so you don't hydro lock it .
as for time my first time , it took 2 days(let the in(3 with the wheel bearings) now i can have it torn down and back together in a afternoon.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 8 Old 03-02-2014, 08:46 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
NoRalPh is online now
post #5 of 8 Old 03-02-2014, 09:51 AM
r_marczak_83's Avatar
When I did mine for the first time it took around 10 hours for injectors and glow plugs. Most of the time was figuring out what tools to use and how to get the hard to reach bolts out of valve covers.
Id say it could be cut in half if I were to do it again.
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #6 of 8 Old 03-02-2014, 02:26 PM Thread Starter
So is the best way to remove the injectors, put the new injectors in and remove the glowplugs, crank the motor with valve cover on partially, then install the glowplugs?
post #7 of 8 Old 03-02-2014, 03:13 PM
Colin7.3's Avatar
thats how i do it. if you remove the end plugs you shouldnt have to crank it with the glow plugs out. but its a pain in the arse to get the rail plugs out and they need new o rings when you pull them. so i just pull injectors, put new injectors in, pull glows. crank engine a few times, youll hear when the cylinders clear out. and put glows back in and your done.
and make sure you put a valve cover back on each side...... ask me how i know how big of a mess it makes
Colin7.3 is offline
post #8 of 8 Old 03-02-2014, 07:06 PM
I made the mistake of hooking injectors up when cranking with gp's out, so I changed oil directly after, since they injected fuel. It's a good idea to leave the harness disconnected.
E99 F250 ex-cab 7.3
