Coolant Leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-01-2014, 06:45 AM Thread Starter
03ranger30's Avatar
Coolant Leak
I got under my truck today to do the trans cooler bypass (to no success) and noticed I had coolant running down the lower radiator hose. I got up top and looked and it seemed to be coming from the thermostat housing, which I know is common. It appears to be leaking from the top of the housing where it mates with the water pump, down and around and onto the hose, which then it runs down to the lowest point and then drips on the ground.
I was just looking for a second opinion as to whether or not this is the culprit or should I look somewhere else.
Here are some pics.
ID:	250425   Click image for larger version
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #2 of 5 Old 03-01-2014, 06:56 AM
belz's Avatar
Quoted: 70 Post(s)
Replace it with the billet one. Can't remember if it was from dieselsite or not.
What happened with the bypass? I replaced mine also.
belzfone
Belz
CPA Director
belz is offline
The Following User Says Thank You to belz For This Useful Post:
03ranger30 (03-01-2014)
post #3 of 5 Old 03-01-2014, 06:59 AM Thread Starter
03ranger30's Avatar
That's what I was looking at doing. New housing, new thermostat, new upper hose (around the belt) and a coolant flush.
Nothing bad happened with the bypass, it's just too cold outside to do it right now and I need more trans cooler line because the factory lines are run in a way that I can't get it to work right without bending them at extreme angles.
Charlie
post #4 of 5 Old 03-01-2014, 07:46 AM
belz's Avatar
Quoted: 70 Post(s)
Oh. Bypass filter. Thought u meant the one that comes on the trans. I did the same thing. Put the 190 t stat, billet housing and dual alt hose. Also put a ghetto fabulous coolant filter. Lol I now think I need to replace the seal on the piece that bolts to the pump for the lower hose.
belzfone
Belz
CPA Director
belz is offline
post #5 of 5 Old 03-01-2014, 07:49 AM Thread Starter
03ranger30's Avatar
No it's the Derale bypass that you splice in the lines so the trans warms up faster.
I would like to get this done sooner rather than later, but the weather is not cooperating and I don't want to be working on my truck in 20*.
Charlie
