Strange howling noise, Think the turbo is dieing? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-27-2014, 08:40 PM Thread Starter
Powerstroke Techie
alabamafrog's Avatar
I noticed a few days ago that my turbo is making a very loud howling sound under hard acceleration on my White truck. Its like 3 or 4 times louder than the normal hiss and has more of a howl or roar sound.
Still running about 25-28 psi boost and the EGT seems to be about the same as always but the sound it is making makes me think something is going to let go very soon.
Any suggestions as to what it could be?
Should I go ahead and order a good aftermarket turbo and if so any recommendation as to which one and who from?
I got the D66 on my purple e99 but as I understand it I have a lot more choices for my white 2000. Id like to stay in the $1,500 or less range and as for now I do not plan to change the injectors until they die.
This is of course assuming it is the turbo, I need to check it out this weekend.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #2 of 8 Old 02-28-2014, 11:58 AM
duck fan's Avatar
If it is your turbo, and you like how the D66 performs on your E99, you cant go wrong with a 38R. Plenty of vendors carry them and most, if not all are well within your budget.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 8 Old 03-02-2014, 06:04 PM Thread Starter
Powerstroke Techie
Finally had time to check it today and the shaft end play is around 3/8" and the wicked wheel looks like its chewing into the housing, so I'm fixin to order me a 38r turbo.
post #4 of 8 Old 03-02-2014, 06:41 PM
nuthinbutfords's Avatar
Quoted: 5 Post(s)
Didn't think a 38r would fit on the e99 trucks?
E99 F250
BDS 4in lift with Fox shocks
20x12 962's on 35in Trail grapps
pro comp ladder bars (want something better)
DP tuner F5 chip
6637 intake
5in MBRP exhaust with 7in tip
05 Harley Davidson front end
Retro Solutions 55w 5k hids
And hopefully more mods to come
nuthinbutfords is offline
post #5 of 8 Old 03-02-2014, 07:59 PM
Quoted: 725 Post(s)
Correct. It won't unless you get the newer pedestal, up pipes, 3" intakes w/ boots, spider pipe.
Corey@CNCFAB is online now
post #6 of 8 Old 03-02-2014, 10:10 PM Thread Starter
Powerstroke Techie
This is my 2000 White truck not my e99 purple truck.
post #7 of 8 Old 03-02-2014, 10:32 PM
Quoted: 725 Post(s)
No problems then. 38R an away you go. :thumbup:
post #8 of 8 Old 03-12-2014, 07:21 AM Thread Starter
Powerstroke Techie
Got the new turbo on Whitey, dang thing sounds like a fighter jet now! Turbo was $1349 on eBay, and I didnt have time to do it so I paid a local shop $280 to install it.
