New to fords - 7.3 NO POWER - Ford Powerstroke Diesel Forum
post #1 of 43 Old 02-27-2014, 08:26 AM Thread Starter
So, i bought this 1999 F350 not running. the previous owner said it overheated and blew up.
I replaced the CPS and then found out the ICP sensor was missing, as i dumped a ton of oil on the ground. lol. i put a new ICP on and cleaned out the fuel filter. I eventually got it running, but it's WAY down on power.
there is no smoke. i was thinking the old fuel was junk, so i drained the tank with a hose and filled with 15 gallons of fresh diesel. also changed the fuel filter for a new one.
if you're driving it, floored, it'll take ~10 seconds to reach ~2500rpm. you can hear the turbo screaming and the check engine light will come on.... as soon as you let off the gas the light goes out.
what should my next move be?
thanks in advance!
iniviate is offline
post #2 of 43 Old 02-27-2014, 09:56 AM
duck fan's Avatar
Since the SES light came on, the very first thing should be to get it scanned to see what the codes are. That should get you started in the right direction.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 43 Old 02-27-2014, 10:44 AM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
Sounds like you blew a boot off. Check for a boost leak.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 43 Old 02-27-2014, 12:45 PM Thread Starter
my code reader says no codes.
they're all good. it's making boost, as i blew off a hose yesterday where the previous owner used a normal hose clamp.
iniviate is offline
post #5 of 43 Old 02-27-2014, 01:12 PM Thread Starter
im reading that a lot of code readers won't work on these trucks.
which one can i buy that will work?
iniviate is offline
post #6 of 43 Old 02-27-2014, 01:18 PM
Macon's Avatar
Auto Enginuity.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
The Following User Says Thank You to Macon For This Useful Post:
Matt7.3PSD (08-27-2014)
post #7 of 43 Old 02-27-2014, 04:13 PM Thread Starter
Originally Posted by Macon View Post
Auto Enginuity.
anything cheaper? i don't own any other fords and this one is likely to get a cummins eventually. (sooner than later if i can't make this motor run. lol )
iniviate is offline
post #8 of 43 Old 02-27-2014, 06:46 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
The torque app for android with a blue tooth obd2 adaptor. It should be around $20-30. Search around here and you will find a lot of info on it.
01 f-250, Standard
sbluke55 is offline
post #9 of 43 Old 02-28-2014, 05:09 AM Thread Starter
that's what i'm talkin about.... thanky sir!
i think today i'm going to pull the valve covers and check the connector in there.
iniviate is offline
post #10 of 43 Old 02-28-2014, 07:27 AM Thread Starter
i pulled the valve covers and i think the drivers side has slipped out a little, maybe a little over 1/16" .... i wasn't really sure what i was looking at though and ended up disconnecting it before trying to push it together.
the passenger side had slipped about 1/8"
both connectors fell apart as soon as i touched the clip though, so i guess i need new VC gaskets.
iniviate is offline
