burning oil and possible coolant - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-25-2014, 04:47 PM Thread Starter
i bought a 01 with 150k dirt cheap from a friend who just bought a new truck and wanted out symptoms some times when you start it cold it won't smoke at all can idle for 30 mins no smoke drive it down the road and will smoke like a pig esp when you get on it and when you come to a stop it'll still smoke blue for a few looks blue could be a lil white can't tell but when you let it idle right after it'll clear up but then some times you start it cold and it'll smoke a blue isn color soons it starts and when you drive it not smoke as much im dum founded I've had mechanics tell me oil cooler I've had mechanics say turbo seals I've had mechanics say head gaskets I've herd injector seals can anyone help me out
gruesomegrundel2 is offline
post #2 of 11 Old 02-26-2014, 11:18 AM
duck fan's Avatar
Originally Posted by gruesomegrundel2 View Post
I bought a 01 with 150k dirt cheap from a friend who just bought a new truck and wanted out. Symptoms: some times when you start it cold it won't smoke at all. Can idle for 30 mins, no smoke. Drive it down the road and will smoke like a pig, esp. when you get on it and when you come to a stop it'll still smoke blue for a few. Looks blue. Could be a lil white, can't tell but when you let it idle right after it'll clear up. Some times you start it cold and it'll smoke a blue-ish color. Soon as it starts and when you drive it not smoke as much. I'm dumb founded. I've had mechanics tell me oil cooler. I've had mechanics say turbo seals. I've had mechanics say head gaskets. I've herd injector seals. Can anyone help me out?
Sorry man, had to go through and plug in some punctuation. That was hard to read which made it hard to figure out what you were saying your issue is.
First question, you say you are burning oil. Are you actually losing oil or are you assuming that based on the smoke color?
Second question, is there any noticeable reduction in performance?
Its probably not a headgasket. They rarely fail on these engines. Is there a chip or any sort of tuner? When was the last oil change and what kind of oil was used?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 11 Old 02-26-2014, 08:20 PM Thread Starter
Loses oil has tons of power and it's bone stock
post #4 of 11 Old 02-26-2014, 08:29 PM
To eliminate injector O-rings pull the fuel filter and check for oil in the bowl. It is more pronounced if the fuel tank is close to empty. Black fuel in the bowl indicates bad injector O-rings. If it looks like this pic you need a set of injector O-rings.
0903132025_zpse8d03f85.jpg Photo by davidcolqui | Photobucket
Ether Baby is offline
post #5 of 11 Old 02-26-2014, 10:43 PM Thread Starter
It's actually on empty I'll check that Tomorro/today thanks
post #6 of 11 Old 02-28-2014, 04:12 PM Thread Starter
Nope fuel bowl is crystal clear and my buddy and I found some coolant on the lower rad house so hopefully figured out the coolant loss
post #7 of 11 Old 03-01-2014, 07:09 PM Thread Starter
so the coolant problem is the water pump, me and my buddy got underneath and theres coolant on the hoses and front of the motor, the next day there was a puddle underneath so that problem is solved. we took off the boost tubes and there filled with oil.. turbo seals?? any one think the same and if I'm doing water pump and turbo i was thinking bought doing injectors seals glow plugs and valve cover harnesses all at once good idea or if its not broken don't fix it ? just figured while I'm in there and its all apart
post #8 of 11 Old 03-01-2014, 08:13 PM
blue99stroker's Avatar
Quoted: 243 Post(s)
the oil is in the intercooler pipes because the ccv vents into the intake.
now if you pull the downpipe and oil is going out the exhaust then you need a turbo rebuild
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #9 of 11 Old 03-05-2014, 04:23 PM
Quoted: 722 Post(s)
Not necessarily on the black fuel.
Pull one injector and observe the oring condition. I'm gonna say there are a few that are dry rotted.
Corey@CNCFAB is online now
post #10 of 11 Old 03-05-2014, 04:36 PM Thread Starter
Bought a Gtp38r from guy on here hopefully that fixes the prob
