Another glow plug problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-21-2014, 12:56 PM Thread Starter
RAMKILLER97's Avatar
Here's the problem, I can't start the truck when it's cold unless it's plugged in. The code I am getting is a p0380 circuit A fault. The GPCM is recieving power but not sending power, and I have replaced it with a new one and the same thing is happening. I pulled the chip to see if that could be it and it gave me a GP 8 circuit fault so I pulled the valve cover and found that one to be unplugged. Plugged it all back together put the chip back in and it's throwing the p0380 code again. I am at a loss now. Any help would be good, thanks.
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
post #2 of 6 Old 02-21-2014, 01:15 PM Thread Starter
Now with the chip back out and cycling the truck a few times no codes are being thrown. Has anyone heard of faulty tuning not allowing the GP to activate?
post #3 of 6 Old 02-21-2014, 01:42 PM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
I haven't but, it IS the PCM that controls the GPs so, it's possible that either the circuit in the PCM that's supposed to activate the plugs is either bad OR the PCM doesn't "know" it's cold enough to use them because of a bad sensor (EOT) OR you just have corroded connectors into the Module.
I don't know a lot about these things but, if I'm not mistaken, pin 8 in the Green plug should be supplied with a Path to Ground, through the PCM to activate that module. Maybe check to see if that's happening to know if the PCM is doing it's job...
NoRalPh is offline
post #4 of 6 Old 02-21-2014, 03:51 PM Thread Starter
Well I am going to try waiting untill tomorrow morning and pull the chip and try to start it, if she fires right up I'll know that's probably it. Wonder if it's tuned for a standard truck and not Cali emissions so it's not functioning properly.
We checked the EOT with the scanner and it was reading properly and come up and down with the truck running and off and what not, I had the same thought. It's never that simple for me haha
post #5 of 6 Old 02-28-2014, 05:05 AM Thread Starter
Well its been narrowed down to the chip. Pulled it before I went on duty wednesday morning and let the truck sit until just this morning. It was 12 with a wind chill of -8 and she started up without being plugged in. So I'll be calling no limit today to figure out about getting the chip re programmed.
post #6 of 6 Old 02-28-2014, 06:57 AM
Quoted: 176 Post(s)
Have you thought about the "Led Mod"? In this weather, when you Really need a working GP system, it's nice to have. Once or twice this Winter I have turned the key to let the plugs do their job and noticed my Led didn't come-on. I recycled the key and it then did (I'll be replacing the GPR this Spring). But, it was Great to know exactly what they system was doing and interesting to watch the GPs come On/Off from inside the cab.
Worth doing if you're having trouble, no "guessing" if they're working or not at Any time
NoRalPh is offline
