Wood pecker in alarm speaker - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-21-2014, 09:21 AM Thread Starter
klookybrown's Avatar
Send a message via AIM to klookybrown
1999 f250 4x4 diesel. 165k miles.
Ok. Not a real woodpecker. But it sounds like one. The sound coming out of the alarm speaker sounds like the alarm is dying and it's making a sound like a woodpecker. It's barely audible unless you walk by the front grill. It is continuous. Yes quite odd.
This is when the truck is just just sitting.
Is there a backup battery?
Sorry if this is the wrong thread to post in.
1999 F250 CC 4x4
I've noticed: Gooseneck hideaway hitch, Rhino Liner , Banks Big Head WGC valve(?), Rear Air bags w/interior control,
K&N filter cold air intake POWR-SLIDER rear window setup , front&rear foglights/area lights-
MORE TO FIND... Check my Garage pics- tell me what's in there I didn't catch!
To Date:
SES code P1249 (MAY 11, 2007) cleared.
SES code P0500 (MAY 25, 2007) cleared.
klookybrown is offline
post #2 of 7 Old 02-26-2014, 11:57 AM Thread Starter
Adding to thread for still needed help.
Both my batteries are good by multimeter check (they're less than a year old each.)
1. Is there a backup battery for the alarm system?
2. Can the alarm 'brain' be reset and its location?
3. Is there a place to upload video for ya'll to hear this?
Thanks...
1999 F250 CC 4x4
To Date:
post #3 of 7 Old 02-26-2014, 12:05 PM
BryceB's Avatar
Is this a factory alarm system? I didn't know that was offered.
Sounds aftermarket.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #4 of 7 Old 02-26-2014, 04:03 PM Thread Starter
Sounds aftermarket.
Ah. Maybe. I bought it used in 2005. Just figured it was factory. Great. Could be anything then. Ugh.
Thanks for replying.
1999 F250 CC 4x4
To Date:
post #5 of 7 Old 03-06-2014, 11:51 AM Thread Starter
Hey guys,
Is there a standard place to find the alarm system? I want to see if it has a battery backup and also maybe just turn it off until I can figure out what's wrong with it as I'm unhooking my batteries just incase it drains them.
1999 F250 CC 4x4
To Date:
post #6 of 7 Old 03-06-2014, 11:52 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
the GEM and most aftermarket alarms will be wired under dash
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 7 Old 03-06-2014, 12:52 PM Thread Starter
Ok. So, I found another website about turning ignition over to run 8 times. I did this and the locks cycled. I'm guessing that means it's factory? I do have a key fob as well.
After doing that I left the key in the ignition, opened the door to go see if alarm was making noises and the alarm went off. I tried turning on ignition but it wouldn't work so I used the fob and it turned it off.
Now there's no noise at the alarm speaker. Bizarre.
I'll be watching to see if sound comes back.
1999 F250 CC 4x4
To Date:
