Contribution Test - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-31-2008, 10:27 AM Thread Starter
Contribution Test
Hello All
I have a 2000 Superduty 7.3 and truck is missing and no power
Did a contribution test this morning and got 2 codes
p0269- Cylinder #3 Injector circuit contribution / Balance fault
p0284- Cylinder #8 Injector circuit contribution / Balance fault
Buzz Test - OK
Glow Plug Test - OK
Some codes that came up on the first initial test
P0236
P0237
P0308
P0470
P0541
P0603
P1280
P1670
Any Help would be greatly Appricated
schortz is offline
post #2 of 13 Old 10-31-2008, 10:33 AM
I am that hot
superxcrewfx4's Avatar
Originally Posted by schortz View Post
Hello All
Buzz Test - OK
Glow Plug Test - OK
P0236 - Turbocharger Boost Sensor A Circuit Range/Performance
P0237 - Turbocharger Boost Sensor A low voltage
P0308 - Cylinder 8 Eight Misfire Detected.
P0470 - Exhaust back pressure sensor circuit malfunction
Probable Causes: Biased sensor, open signal return
P0541 -Intake Air Heater Relay 1 Low
P0603 - Ctrl Mod KAM Error
P1280 - icp low
P1670 - Electronic Feedback Signal Not Detected
Common for the #8 injector to go bad, I have a new one already
1999.5 Ford F-250 Powerstroke
7.3 Powerstroke Diesel
4" Turbo Back MBRP with 6" Tip Straight Piped!
DIY Intake
Isspro Gauges
Diesel Site Coolant Filter
TW 6 Position Chip
2.5 Inch Leveling Kit
305/75/16 Mickey Thompson MTZ's
239k and COUNTING!!!
superxcrewfx4 is offline
post #3 of 13 Old 10-31-2008, 10:40 AM
cant really help ya, have kinda the same probs. so here is a bump
2001 F-350 4x4 SRW CCLB
DIY INTAKE
BTS TRANNY
6.0 TRANNY COOLER
BTS TUNES
HpXover LINE
ISSPRO 3 GAUGE A PILLAR MOUNT
WICKED WHEEL
ZOODAD
FUEL PRESSURE GAUGE
4" TB EXHAUST
2005 F-350 4x4 SRW CCLB
coolant filter
cat delete
RCD up-pipe = home brew EGR delete
Fast_Frank is offline
post #4 of 13 Old 10-31-2008, 10:43 AM
jlarsen's Avatar
I've got #3 and #8 fault as well runs great so I haven't torn into it.
2002 F350 Crew cab Lariat
Power Hungry Performance Gryphon- Custom Tunes
GTP38R
Bellowed Up pipes
NON-EBP Pedistal
4 Inch Lift and 35 inch Goodyear DuraTracs
AFE Stage 2 Pro Guard 7
MBRP 4 inch turbo back
GDS High flow power outlet
Zoodad mod
Tranny cooler
Trans go shift kit
Airlift Bags with compressor
1996 extended cab 4x4 Powerstroke TOTALED
5 speed, heavy duty clutch
AFE stage 2 intake pro guard 7 filter
4 inch Diamond Eye turbo back exhaust
cat delete
TW chip
jlarsen is offline
post #5 of 13 Old 10-31-2008, 03:01 PM Thread Starter
Pulled valve covers . connection under valve cover were loose, pushed back togeather . The truck is running 100% better. I cleared all codes before I took it for test drive. Hooked back up to lap top with Auto Enginuity and got these codes
P0308
P0470
P0541
Did contribution test
Any help would be greatly appricated
2000 F-250 Super Duty 7.3
6 Speed Manual Tranny
Dp Turner 60 Tow, 80 Econ, 120 Race, 140 Extreme
ITP Boost Fooler
Banks 2 GAUGE A PILLAR MOUNT
Afe Stage 2 intake
Garrett turbo
Banks Power Elbo
4" MBRP EXHAUST
schortz is offline
post #6 of 13 Old 10-31-2008, 03:04 PM
I am that hot
You still need to replace those 2 injectors. The intake air heater doesnt really matter and the boost thing is related to some sort of issue with your turbo.
DIY Intake
Isspro Gauges
TW 6 Position Chip
post #7 of 13 Old 11-02-2008, 01:40 PM
Broncoguy's Avatar
Cylinder Contribution
Ran the same tests on mine and got the #8 balance fault also. P 0284.
So does this mean the injector is bad, or could it be the injector harness under the valve cover?
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #8 of 13 Old 11-02-2008, 04:37 PM
I get a P0284 on mine also. Runs great so I haven't done anything yet.
Toptech is offline
post #9 of 13 Old 11-02-2008, 04:43 PM
Other vehicle is an F250
Hank's Avatar
I get a #8 fault everytime I run the test. Is there a problem with waiting to replace it?
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #10 of 13 Old 11-03-2008, 08:48 PM Thread Starter
Will there a problem waiting to change the inectors
ITP Boost Fooler
Afe Stage 2 intake
Garrett turbo
Banks Power Elbo
4" MBRP EXHAUST
schortz is offline
