2000 turbo down pipe came loose from the turbo - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-15-2014, 07:32 PM Thread Starter
The pipe exiting the turbo came loose today. I am getting a service engine light flashing. I recently had the engine pulled to replace the oil pan and timing cover. My guess is the clamp didn't get tightened enough when the engine went back in the truck. Is this an easy fix ? Thanks.
JLimb is offline
post #2 of 2 Old 02-15-2014, 07:39 PM
hansel's Avatar
Quoted: 95 Post(s)
I would think it would be fairly easy, you would need to loosen the pipe where it bolts too the rest of the exhaust then readjust the pipe too the turbo, and tighten it up then tighten up the rest.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
