*911* 7.3L not starting. - Ford Powerstroke Diesel Forum
post #1 of 23 Old 02-09-2014, 11:56 AM Thread Starter
CoalRollinRoosterCruiser's Avatar
Helping a buddy work on his uncle's 2000 7.3l. Truck is not starting unless plugged in for a couple hours. And even then it barely starts. WILL NOT start cold in 50* weather. And we are not getting any smoke while motor is turning over.
Glow plugs have been replaced. Valve cover gaskets and uvch's have been replaced. ICP has been replaced. IDM was switched out with good working IDM, no change.
Batteries are good, and have jump box has been hooked up also.
Motor is turning over fast, just not starting.
HPOP is full of oil. Fuel bowl is full as well, and when emptied fills up as it should.
We are now stumped as to why its not starting.
Y'all got any ideas?
Sent from AutoGuide.com App
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #2 of 23 Old 02-09-2014, 12:01 PM
1997PSD's Avatar
Quoted: 2 Post(s)
have you replaced the Glow plug relay?
2000 F-250 XLT
Twisted Diesel Level II 4R100 w/ V10 Cooler
TS 6 Position w/ PHP Tunes.
4 inch turbo back straight pipe.
Wicked Wheel 2
18in XD's wrapped in 35in Toyo Open Country M/Ts
3 inch PMF shackles w/ Ford X-codes.
Re-routed CCV
Red Head Steering Gear
Isspro A-pillar Gauges.
7 inch pioneer touch screen.
'07 grille and Morimoto Retro'd headlights
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #3 of 23 Old 02-09-2014, 12:06 PM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Might be Injectors are tired, read through this-> http://www.swampsdiesel.com/files/7....Diagnostic.pdf
More good Info that might apply -> 2003 7.3 wont start help please
NoRalPh is offline
post #4 of 23 Old 02-09-2014, 12:12 PM Thread Starter
Yeaupp glow plug relay has been replaced as well
post #5 of 23 Old 02-09-2014, 01:09 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 115 Post(s)
You might need a new ignition switch. Do all your lights inside and everything work?
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #6 of 23 Old 02-09-2014, 01:14 PM Thread Starter
Yeah it has had an ignition switch put in it recently
post #7 of 23 Old 02-09-2014, 01:19 PM
Colin7.3's Avatar
have you read the IPR % and ICP pressure?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #8 of 23 Old 02-09-2014, 01:20 PM Thread Starter
Yeauppp. IPR% is good. And ICP pressure is where it should be
post #9 of 23 Old 02-09-2014, 01:24 PM
Colin7.3's Avatar
when it starts does it miss and shake really badly?
Colin7.3 is offline
post #10 of 23 Old 02-09-2014, 01:40 PM Thread Starter
Yes big time for at least 10 min. But will only start when plugged in for a few hours. And even then it takes it a bit to get started
