2000 7.3 will not start unless plugged in - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-08-2014, 10:51 AM Thread Starter
My truck will not start (turns over) unless I plug it in for a couple hours. When it fails to start, it seems to be trying to run on less than 8 cylinders and produces white smoke. When plugged in, it starts and runs fine.
I replaced the gpr with a Stancor. I checked the glow plug resistance. All of the GPs have resistance between 1.8 and 2.0 ohms. Is that too much resistance? The connector outside the valve cover looks ok (not melted or discolored).
I would appreciate advice
Thanks Scott
Homebrew is offline
post #2 of 15 Old 02-08-2014, 11:49 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Have you confirmed that the GPR is activating? That is, you have voltage on Both large terminals when they should be on?
NoRalPh is offline
post #3 of 15 Old 02-08-2014, 01:14 PM Thread Starter
Yes. After I installed it, I had 11.7 on the always hot side and a little less (11.5 v) on the other side when the key is on (zero when it is off). I couldn't get it started right after installing the gpr, so I plugged it up to Ac and put chargers on the batteries. The batteries were purchased a little over two years ago (11/2011).
Thanks
Homebrew is offline
post #4 of 15 Old 02-08-2014, 01:47 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
this sort of stuff is usually associated with bag glow plugs or relay but maybe your icp sensor is bad. pull the connector off the icp and if theres oil replace it.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 15 Old 02-09-2014, 11:33 AM Thread Starter
I pulled the icp connector off and inspected it - looks good, no oil. I am trying to eliminate what I can before replacing the glow plugs. Do you think I should test/inspect other things?
Also, are there any brands or places I should avoid when buying new GPs, valve cover gaskets or GP wire harness?
Thanks -Scott
Homebrew is offline
post #6 of 15 Old 02-09-2014, 11:46 AM
Quoted: 244 Post(s)
motocraft plugs only.
motorcraft or interational injector harness only.
valve cover gaskets never wear out on these, occasionally one will get melted but thats pretty rare.
The Following User Says Thank You to blue99stroker For This Useful Post:
Homebrew (02-09-2014)
post #7 of 15 Old 02-09-2014, 11:58 AM
Joe0816's Avatar
Try actually unplugging the ICP and try to start it. Just because there is no oil in the sensor doesn't mean it isn't bad.
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #8 of 15 Old 02-09-2014, 12:11 PM Thread Starter
Ok. It starts with the icp plugged and unplugged. Unplugged gives a check engine light. Plugged icp back in and the light is out. (It is warm today, 60 - started without being plugged to AC)
Homebrew is offline
post #9 of 15 Old 02-09-2014, 12:13 PM Thread Starter
Thanks, I'll stick to Motorcraft
Homebrew is offline
post #10 of 15 Old 02-09-2014, 12:17 PM
Joe0816's Avatar
unplugged will give a CEL, yes. But the next time it is cold and you are having problems, unplug it and give it a shot. If it starts up, you know to replace the ICP sensor.
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
Tags
glow plug , glow plug relay , white smoke , will not start cold
