injector replacement problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-06-2014, 09:46 AM Thread Starter
hello, 99 7.3 220,000 miles. Service engine soon light came on mechanic ran code said electrical problem injector 7. he replaced injector 7 now truck runs ruff steady smoke and sometimes locks when you turn it over. any ideas? thanks for any help
tbenn50563 is offline
post #2 of 7 Old 02-13-2014, 07:18 AM
wireman116's Avatar
sounds like a wire pinched. Take your valve cover off, crank the truck & see if it still runs ruff
wireman116 is offline
post #3 of 7 Old 02-13-2014, 02:43 PM
Solid98's Avatar
Quoted: 8 Post(s)
Locks as in stops cranking? Like it seizes up?
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #4 of 7 Old 02-27-2014, 07:39 AM
I'm no expert but it Sounds like injector oil leaking into the cylinder of the injector he replaced. Better take it back before you have big problems.
BigAssTruck is offline
post #5 of 7 Old 02-27-2014, 10:57 AM
duck fan's Avatar
How many miles if any on the new injector?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #6 of 7 Old 03-05-2014, 04:33 PM
Quoted: 722 Post(s)
Ya. Sounds like the mech ruined an oring while trying to put the new injector in and is loosing hpop pressure and filling that cylinder with oil. Could be bad internal O-rings on that injector too.
Corey@CNCFAB is online now
post #7 of 7 Old 03-05-2014, 05:18 PM
E99F350Stroker's Avatar
If there are damaged O-rings and fluid drains down in the cylinder it can cause serious problems.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
