oil leak
Hey guys. I am new here and I just bought a 2002 F-350 Lariat 4x4 Crew Cab Short Box with 114,000 miles on it. I noticed it seems to leak a little oil right below the fuel filter on the intake. Can anyone tell me what could be leaking in that area and how to fix it. I am 25 and have been working on gas motors since I was 13 with my dad so I am mechanically able to do the work and also my dad was a diesel mechanic working on Cat motors many years ago so he has knowledge about diesel motors but he seen this Powerstroke and was like "that's a new animal to me son, too many electronics". Thanks for any help guys.
Ok I found the leak. Apparently when someone worked on the truck they did not get the o ring seated properly on one of the fittings on the high pressure oil pump. It is hanging about half way out.
Got lucky there didja? Hey make sure your oil filter is on nice and tight. For some reason every now and then mine likes to work it's way loose. I get it tight to the recommended "tightness" every time and put the recommended swath of oil on the seal.......must be all the vibration I don't know?!!!
Very lucky and very happy that is all it was.
I know i got scared to death when I saw the little oil spots under my truck. I breathed the biggest sigh of relieft when I found it was just another slightly loose filter.
the o ring on the quick connect fitting you ended up finding is an extrememly common 7.3 oil leak. it was a bad design to seal with the pressure that pump puts out, and those o rings blow relativley regularly. trick to fixing it is get the kit from ford, it will be three pink o rings and some locktite. make sure when you replace them not to over torque the fitting, torque spec i beleive is only like 12 foot pounds, although the instructions in the parts package have the exact spec. the third o ring is for the 18mm plug on the back of the pump. there is a special tool for releasing the lines from the fitting, and without it you need to be very carefull not to damage the line or it will leak.
Hey thanks mschn99. I am not going to be the one fixing it because I seen it needed a special tool. We have a friend that has worked for Robinson Brothers Ford Licoln Mercury as a mechanic for 17 years and he will be the one fixing it for me. I really appreciate the advice. This guy is not a diesel tech but they have one in the shop and I am sure he will have this tool. I really appreciate it.
anytime, it is probably a wise choice to have a dealer do it anyway as they will leak again if it isnt done right, plus the ford repair will pack a 12/12 warranty if that guy messes it up
leak...
hey good deal proline, but our dealer in our town pretty much won't touch anything deisel becuase they really dont have any techs qualified. how ever something i want to bring up as for as me being a lube tech and see a lot of, some may or may not know that on the backside of the intake there is a drain hole for any fluids. SO! if you see oil dripping down the back side of the motor dont jump to conclusions. always start high and towards the front, as oil will leak to the intake and run towards the rear, and drip down the back of the motor making it look like a rear main, heads, intake, high pressure seal to turbo are leaking and so on....... investigate first!!!
Well I had my friend order me the Ford part to remove the lines. $7.49. I bought the o-ring kit and started today replacing them. 2 hours later it is done and no more leaks.
As stated I have been working on cars for around 15 years and my dad for over 35 years so I am sure it is done right. Before the oil coming out was a steady stream on the front fitting. Maybe I am crazy but now the truck seems to idle a little smother and actually seems to have a little more get up and go especially when going uphill. Maybe it's true or maybe I am just glad to finally have it fixed.
