IPR or HPOP - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-01-2014, 05:57 AM Thread Starter
redogg322's Avatar
Send a message via AIM to redogg322
IPR or HPOP
When I pull the ipr valve should the oil drain into the valley? If it does not does that mean the hpop is bad? 2000 7.3 with the scanner hooked up it only shows 80 psi inj. Pressure.
00 f-350 4 door long bed 4X4
Nitto Terra Grapplers
7.3 4" downpipe with 5 " Exhaust Stacks
[EMAIL="
redogg322 is offline
post #2 of 4 Old 02-01-2014, 07:15 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
yes oil should drain out of the hole.
it takes 500 psi to start the truck.
so im not sure what reading you are getting.
could be the lpop not feeding the hpop but im not sure.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 4 Old 02-01-2014, 12:34 PM Thread Starter
redogg322's Avatar
It has plenty of oil in the hpop reservoir. No oil is draining through the pump
[EMAIL="
post #4 of 4 Old 02-01-2014, 08:55 PM
harness00's Avatar
screen in the reservoir could be plugged up keeping oil from getting to the pump
harness00 2000 ford f-250 7.3 psd swamps hybrid 250/100% injectors, swamps high frequency idm, custom ts chip, garrett gtp38r turbo, k&n intake, banks techni cooler, hpx cross over line, fuel lab prodigy fuel pump, south bend ceramic button clutch, adrenaline hpop, driven regulated return, swamps high rate valve springs, smith brothers billet pushrods, 4in down pipe 5in exhaust, 5" miter cut black stack, soon to be 7" hood stack probably.
harness00 is offline
