02 7.3 starting issue. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-31-2014, 07:15 PM Thread Starter
Hello everyone. I need some help kinda stumped. I recently replaced both battery's and altinator, started fine for a week or so, now when I start it it sounds like the battery's are dead but it starts and both battery's read 13.2 volts before during and after start up. Also all electronics seem fine. I could tell last time batts were bad by the window up/down speed. HELP PLEASE!!
Jarp is offline
post #2 of 5 Old 01-31-2014, 07:28 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Check for corrosion on the starter terminal wire or the starter could be going out
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 5 Old 02-01-2014, 07:28 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
If you read 13.2v during starting, something's wrong!
No "work" is being done and, at the Very Least, the GP system should draw-down the voltage by a couple of volts before you even engage the Starter.
NoRalPh is offline
post #4 of 5 Old 02-01-2014, 08:20 PM
harness00's Avatar
I would check the cable connections at the batteries and starter mine was doing that i cleaned all the battery terminals and it starts like a champ again
harness00 2000 ford f-250 7.3 psd swamps hybrid 250/100% injectors, swamps high frequency idm, custom ts chip, garrett gtp38r turbo, k&n intake, banks techni cooler, hpx cross over line, fuel lab prodigy fuel pump, south bend ceramic button clutch, adrenaline hpop, driven regulated return, swamps high rate valve springs, smith brothers billet pushrods, 4in down pipe 5in exhaust, 5" miter cut black stack, soon to be 7" hood stack probably.
harness00 is offline
post #5 of 5 Old 02-01-2014, 08:28 PM Thread Starter
Will do man thanks.
Jarp is offline
