7.3 just died! - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 21 Old 01-30-2014, 03:10 PM Thread Starter
7.3 just died!
I was driving my truck down a gravel road when it just dies and now it wont restart. When I crank it, no oil pressure shows up either. I seriously don't know what to do, I need the truck pretty fast this weekend for a hay haul. I was told could be the oil pump or the oil pressure sensor (Not sure if this is right?), but I'm not sure.
1999 F250 with 1 tone axles, 7.3 Powerstroke, 268,000 miles, ZF6 transmission, 4x4, cold air intake, straight piped, Edge programmer.
Firefighter186 is offline
post #2 of 21 Old 01-30-2014, 03:20 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
My usual No Start -
WTS Light? - do you get it when you first roll-on the key? (shows the computer is running)
Do you see cranking rpm on the Tach? Do you have a spare CPS to try?
Is there fuel in the fuel bowl now? Does it refill after cranking? (open the drain level to check)
Can you hear/feel the pump running (below the dr seat, against the framerail)
Could the fuel gauge be giving a bad reading? (Below 1/4 tank?)
Is it cranking fast enough? - it won't even TRY to start if cranking too slowly.
Is your truck "chipped"? If so, remove it as a Test.
Firefighter186 likes this.
NoRalPh is offline
post #3 of 21 Old 01-30-2014, 05:29 PM Thread Starter
Yes
Yes
Yes
Yes
Gas gauge doesn't work
It's cranking pretty fast. Faster than my tractors.
To remove it, do I need to disconnect the batteries?
post #4 of 21 Old 01-30-2014, 06:53 PM
shiz big red's Avatar
Yes disconnect the batteries, check the oil level in your hpop.
shiz big red is offline
post #5 of 21 Old 01-30-2014, 06:58 PM Thread Starter
Going to sound really dumb asking this. How do you check the HPOP oil level?
post #6 of 21 Old 01-30-2014, 07:25 PM
There is a plug on the top of the hpop I believe its on the drivers side. Its not a dumb question.
The Following User Says Thank You to shiz big red For This Useful Post:
Firefighter186 (02-01-2014)
post #7 of 21 Old 02-01-2014, 04:13 PM Thread Starter
I'm replacing the PCM to see if that is what it is. I got a new one Friday, but when I opened up the box, the New PCM was broke
post #8 of 21 Old 02-01-2014, 07:17 PM
the1laf's Avatar
Check the Fuse going to the PCM under the dash, the fuel bowl heater is on the same circuit...
Unplug the fuel bowl heater (back of the fuel bowl, almost at the bottom) replace the fuse and try it...
This has happened several times to our fleet of 7.3's, my personal vehicle included.
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
The Following User Says Thank You to the1laf For This Useful Post:
post #9 of 21 Old 02-01-2014, 08:52 PM Thread Starter
I will try that on Monday once I'm off my 24 hour shift. Thanks for the info everyone. I'm also getting a new PCM on Monday as well, so I'll do that and the PCM at the same time.
post #10 of 21 Old 02-02-2014, 05:58 AM
Quoted: 157 Post(s)
But Wait,,,, you have a WTS!
What that's telling you is that your PCM is Up & Running (that's why I ask)
Did you remove the tuning?
NoRalPh is offline
