01 7.3 hpop leak from rear? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-29-2014, 06:05 AM Thread Starter
Infinite's Avatar
Exclamation 01 7.3 hpop leak from rear?
Morning peeps, started noticing an oil puddle under truck..was told was rear main...replaced it..the, found leak continued. .found oil drip from rear of hpop. Not leaking from lines..cant tell if leaking from oring on rear.i can see drip from under the back of the pump. .looks like the rear has a snap ring? Not sure what its called..but that looks all wet..can that leak also? Or where would it leak to make it look like that? ? Any help/ suggestions would be appreciated. .thanks!
Infinite is offline
post #2 of 8 Old 01-29-2014, 12:04 PM
SuperCrutyPS's Avatar
Quoted: 334 Post(s)
Garage
How does the valley look? Oil in it or dry? I ask because there's a weep hole toward the back of the engine and if there's oil in the valley, it could be going through the drip hole and down the back of the engine.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #3 of 8 Old 01-29-2014, 12:12 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 461 Post(s)
Is there oil in the snap ring area or just from the bottom of the pump? If on bottom its one of 2 things. The non serviceable plug (which is serviceable on a bench) or the gasket where the pump bolts to. I have also seen the screen oring gasket fail which is the housing that mounts just above the hpop. Good luck
@loxdce
LoxDiesel is offline
post #4 of 8 Old 01-29-2014, 12:26 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
5 bucks its the stupid end plug!
mine was leaking i figured it was the gasket, turns out the end plug came loose and it needed a new o-ring.
7 dollar o-ring kit and it was fixed.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #5 of 8 Old 01-29-2014, 05:47 PM Thread Starter
Infinite's Avatar
ok, just got home from work..the valley is wet, plus it doesnt help my drive way is in an incline, but nevertheless wether its inclined or on level ground the valley is wet and constant dripping unless she isnt running. its at the point i have to put in about a gal of oil every other day. The rear of the pump where the snap ring is is wet on the bottom lip, looks like a possible drip from rear plug..unforntunately i cant or dont know how to attach a pic...is that snap ring replaceable or is there a gasket behind it??
Infinite is offline
post #6 of 8 Old 01-29-2014, 06:01 PM Thread Starter
Infinite's Avatar
By the way Im still new to Diesels, and still trying figure out all the acronyms..lol..but which is the end plug on the pump?
Infinite is offline
post #7 of 8 Old 01-29-2014, 06:21 PM
Quoted: 283 Post(s)
mine was leaking the same way!
go outside and tighten the plug to see if its loose, mine was. and the oring needed changing as well.
go to dieselorings and look at their schematic on rebuilding the hpop.
check the end plug, not the non serviceable plug.
the end plug is easy to reach with a ratchet.
the plug is to the right and above the back plate with the snap ring.
the back plate with the snap ring apparently doesn't leak very often.
The Following User Says Thank You to blue99stroker For This Useful Post:
Infinite (01-29-2014)
post #8 of 8 Old 01-30-2014, 07:01 PM Thread Starter
Infinite's Avatar
Thanks so much about teling me to check the end plug..it was slightly loose..tightened it up and no leak! ! Greatly appreciated. .never thought something so small could make such a big mess!
Infinite is offline
