rough idle, lack of power, oil in ICP - Ford Powerstroke Diesel Forum
Old 11-22-2006, 07:37 PM
98' psd,
started out as hard to start(even when warm) then check engine light is on, won't rev past about 2300 (lot of white/ grey smoke) so i drive it a bit and the check engine light goes out, revs good again, but still lacks any power. i started out looking for loose / cracked or broken connectors, no oil leaks, no fuel leaks, new fuel filter about 200 miles ago, in this checking i found that when i removed the connector for the ICP it had oil in it. Could the ICP shorting out cause the aove simptoms?
thanks for any help, marc
Old 11-22-2006, 07:42 PM
I don't know nuttin....
Yes....thats the first place i would start.
