Lots of White smoke on start up - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-21-2014, 07:52 PM Thread Starter
Prew32's Avatar
Quoted: 12 Post(s)
Send a message via AIM to Prew32
So since it has been getting cold i have been getting an excessive amount of white smoke on start up. i have read all the posts on this common problem and I was able to test my GP relay and my gp's today and came up with these numbers-
with the key on relay was 11.41 on hot side and 11.21 on gp side and for the glow plugs 5 were .6, 2 bounced back and forth between .5 and .6 and the last one bounced back and forth between .4 and .5
I have read a couple different threads that say that the min should be .6 and a few others that say .8 should be the min with a max of 2. should mine be ok or should they be replaced??
15 F350 CCLB 6.7 Many mods to come.....
01 F350 CCLB 7.3 6 Speed SOLD
Prew32 is offline
post #2 of 12 Old 01-21-2014, 08:10 PM
Powerstroke_21's Avatar
To be honest, and I'm no expert, I'd say they're fine. I know a lot of guys with 7.3's including mine that have some white smoke on start up when it's cold. How excessive is an excessive amount? Like enough to smoke out an intersection if you were driving?
Sent from AutoGuide.com App
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #3 of 12 Old 01-21-2014, 08:18 PM
Rodslinger's B1TCH
I think anything less than 2 ohms is acceptable. Less than one is perfect... I think mine all tested at 1.4 new.
I think that having the ebpv unplugged makes a difference too. I had mine plugged in last winter and don't remember it chugging smoke like it has been this season. I'm thinking that hot air being held in would help with cold ignition.
steve604 is offline
post #4 of 12 Old 01-21-2014, 08:45 PM Thread Starter
Prew32's Avatar
Quoted: 12 Post(s)
ya plenty of smoke to smoke out an intersection. I live in a residential neighborhood and I dread every cold start cuz it just about leaves the entire Street in a cloud of white smoke
Prew32 is offline
post #5 of 12 Old 01-21-2014, 08:50 PM Thread Starter
Prew32's Avatar
Quoted: 12 Post(s)
Ya you are right about the ebpv, I have a high idle setting that shuts the valve and it stops the white smoke if I kick it into that setting but recently the valve had been getting stuck shut when I start driving so I stopped using it. Also I'm getting ready to delete the ebpv soon so that won't be an option for very much longer
Prew32 is offline
post #6 of 12 Old 01-21-2014, 09:28 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Nature of the beast... set your Ebrake ( make sure the dash light comes on) and the AIH will activate and it will kill a lot of the smoke. That's actually the exact purpose of the AIH, it doesn't help starting.
Mine smokes like this.... has since I've owned it ( 3 winters) the colder it is, the worse it is, this is at -32*C after running for less than a minute, itll smoke for about 10 on high idle.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #7 of 12 Old 01-22-2014, 06:44 AM
Rodslinger's B1TCH
If you have power at your house you can plug the block heater in at night. Your truck and your neighbours will love you for it.
steve604 is offline
post #8 of 12 Old 01-22-2014, 11:55 AM
schlutzer's Avatar
Quoted: 18 Post(s)
My truck will smoke like that plugged in or not.
post #9 of 12 Old 01-22-2014, 12:49 PM
Rodslinger's B1TCH
Are you sure the block heater works? The engine should feel warm all around after a night plugged in. Mine smokes out my neighbours when it's freezing out but with the block heater there is no smoke and a lot less noise.
steve604 is offline
post #10 of 12 Old 01-22-2014, 01:21 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Come on over to Northern Ontario ( not Stratford I'm working out of the area for the winter) where temps regularly dip below -30 before the wind chill.
Everything on my truck works just fine lol. It's just how it works when it's cold like I said before, setting the ebrake will allow the AIH to activate which was designed for exactly this purpose.
The Following User Says Thank You to schlutzer For This Useful Post:
Gumbled (02-19-2014)
