ticking, low boost, high pitched air hiss - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-21-2014, 04:12 PM Thread Starter
irfreddy's Avatar
Nothing bit problems with both 7.3s I've owned. Getting a 6.0 next time... -_-
So got the truck running again, now I.noticed higher.rpm and building.boost I got a high.pitched.air.hiss, at 15psi, Max the motor.will reach.now..
Im. Pretty sure that's a.loose boot clamp,It got.stripped
Now I can only.make it to 10psi ish. At idle it sounds normal, but under throttle it starts ticking, louder and louder but not so much faster as the rpm goes up. So makes me believe its not a valve train part.
I'm thinking injectors? What else???
irfreddy is offline
post #2 of 13 Old 01-21-2014, 04:18 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What oil do you use and how long since it was changed?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 13 Old 01-21-2014, 04:39 PM Thread Starter
irfreddy's Avatar
I changed.it in.September.with rotella. Then changed it.again.a couple.months ago.when all.my.oil blew out(loose bolts.holding the Turbo to the block when I did my exhaust).
irfreddy is offline
post #4 of 13 Old 01-21-2014, 06:11 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
buy or build a boost leak detector to find the problem.
there is atleast 10 different places it could be leaking from.
im hitting 35 with stock injectors
but ive been under the hood a lot fixing stuff and making sure i have no boost leaks
and 15 psi is about the highest a stock 7.3 will boost. you can try unplugging the red from the wastegate for a couple more.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #5 of 13 Old 01-21-2014, 11:08 PM Thread Starter
irfreddy's Avatar
Nah I got 25psi at the most before this all happened. And I'm more concerned about the.ticking
Pretty sure the hiss is just the loose clamp. The ticking scares me.a bit. It suddenly started while driving down the road, now keeps doing it
irfreddy is offline
post #6 of 13 Old 01-22-2014, 01:08 AM
Quoted: 283 Post(s)
are your up pipes leaking? if its not something motor related id say you have exhaust leak. that would explain the ticking.
a bent pushrod would be a pretty loud whump whump whump, and those rarely happen.
im guessing you never had to do head studs, or oil cooler, egr, injectors on a 6.0, any of those is more expensive than fixing practically anything on a 7.3.0
which clamp is leaking? the one on the CAC tubes or the clamps on the intake manifold.
if its the intake manifold you can get away with using regular clamps to hold those boots on.
post #7 of 13 Old 01-22-2014, 05:18 AM Thread Starter
irfreddy's Avatar
Up pipes all the sudden though? I was driving and while going down the road, boom, started ticking, loudly. It doesn't get quicker with the rpm wither, just louder.
The clamp is the one on the drivers side of the intwrcooler on the boot to pipe connection
irfreddy is offline
post #8 of 13 Old 01-29-2014, 08:02 PM Thread Starter
irfreddy's Avatar
Its really as loud as it seems. I was wrong, it does increase with rpm, I had a lot on my mind and missed that before. So just a nasty rocker tick? If so would one be broken, cause it started doing it in a second, not gradually over its 195k mile life.
irfreddy is offline
post #9 of 13 Old 01-29-2014, 10:30 PM
Rodslinger's B1TCH
That sounds like an exhaust leak to me. Look for black soot around the manifolds.
steve604 is offline
post #10 of 13 Old 01-29-2014, 10:35 PM
Quoted: 283 Post(s)
ya i think so too.
just because lack of boost.
a bent pushrod would be much louder and rougher.
