Serious Fuel PSI Issues (not the normal newby problems) - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-20-2014, 11:08 PM Thread Starter
Fellas....
I am having some serious fuel pressure issues and was wondering if someone could throw me a life line before I have a mental meltdown. Ive got an 00 with 240K on the clock, stock injectors, a few bolt ons, and a TS chip. Ive already dropped the tank and checked for a plugged screen (it was fine), just replaced original fuel pump with a Bosch (twice), rebulit fuel bowl, changed filter, installed Riffraff regualted return with the fuel rail cross over (using the 61-65psi spring), pulled and resealed injectors with good quality Allaint O rings, injectors all pass buzz test, and on and on all in trying to reslove my fuel pressure issue...have I missed something? At idle im running about 60psi and at WOT under load I can drop it below 20psi (regardless of chip position)The truck has half the power it used to and is progressively getting worse. One thing I have noticed is with key on/engine off once the fuel pump cylces off pressure drops off fast...is this normal? Shouldnt pressure somewhat hold steady after pump cycles off? There is no evidence of any leaks and no smell of fuel...im beginning to wonder if somehow im sucking air between the tank and pump? Please help...im fresh out of ideas!
Thanks
Dennis
00greenmachine is offline
post #2 of 17 Old 01-23-2014, 12:58 PM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
I'm kinda confused. What do you have a fuel crossover kit or a regulated return? If you have a line that runs from each head and you retain the stock fuel pressure regulator with a different spring, you have a crossover kit. If you have a aftermarket regulator and fuel lines running to the front of the heads then return from the back to the regulator you have a regulated return system. If it is the crossover kit, pull the stock regulator apart and make sure you don't have any junk in there causing you to lose fuel pressure. Also you can check the mixing chamber on your pickup( it's the white part on you fuel pick up) it has a couple of screens inside.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 17 Old 01-25-2014, 06:33 PM
timmyboy76's Avatar
air can be pulled from the "feed" line from, tank to pump. Get rid of it and install 3/8 line, and double up the clamps. Also, the fuel pressure drop is completely normal...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 17 Old 01-26-2014, 09:44 PM Thread Starter
I have the "fuel rail crossover" kit from Riffraff listed under their "regulated return system" section for 7.3's Fuel Rail Crossover? (FRx) - Riffraff Diesel Performance It comes with 3 different springs to adjust fuel preesure, im running the middle spring (gold) which is supposed to be rated at 61-65 psi. As far as the mixing chamber, ive already had the tank down and the pickup out. Its been a while but as I remember the screen at the bottom of the pickup had a little debris but nothing close to what ive heard people describe theve found. I was going to do the mod everyone talks about in the tank and mount an inline spin on filter on the frame but was in a hurry and didnt have time. As I recall the screens in the mixer I believe looked ok as well. Any other ideas? At this point im grasping for straws and welcome any ideas anyone may have.
Thanks!
Dennis
post #5 of 17 Old 01-26-2014, 10:02 PM Thread Starter
That is a good idea and running new rigid line from the tank to the pump will probably be my next step. The only idea I have left is perhaps I have a bad quick connect somewhere on the suction side. As far as the fuel pressure drop...it is NOT normal to drop below 20 psi in which I can do easily when loaded under WOT. I have a drastic reduction in power and have difficulty pulling my loaded car hauler (aprx 6K pounds) up the slightest grades and maintaing 75MPH in OD. It used to smoke like a frieght train on the 100HP setting and now I cant hardly even get a puff even when lugging so im positive it is a fuel issue. As said before, I resealed the injectors and adressed everything I thought could be a possibilty when I had the engine out for the oil pan change.
Keep the ideas coming...I need them!
Thanks
Dennis
post #6 of 17 Old 01-26-2014, 10:11 PM Thread Starter
Something else I would like to confirm is...could someone please post how long it takes or how fast psi should drop or not drop with key on engine off after pump cycles?
Another words key on, pump comes on and builds 60+ with engine off, after aprx 6-8 sec pump kicks off then psi drops like a rock. Is it normal for pressure to drop once pump kicks off or shouldnt it hold?
post #7 of 17 Old 01-27-2014, 06:54 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
Your pressure should hold longer than a few seconds. If you have no visible leaks I would say your fuel pressure regulator is acting up. Get a rebuild kit for it from dieselorings. Make sure everything is clean and without damage. Guzzlers has a write up in how to rebuild your fuel bowl. Here is the link. http://www.guzzle7pt3.com/fbowl.php
01 f-250, Standard
sbluke55 is offline
post #8 of 17 Old 01-27-2014, 07:00 AM Thread Starter
I rebuilt the fuel bowl when I had the engine out and resealed the injectors. The factory regulator was replaced when I installed the Riffraff kit for the regulated return. I checked this morning as soon as the pump kicks off the pressure immidiently drops to 0.
post #9 of 17 Old 01-27-2014, 08:22 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
I looked at the instructions for the kit you have installed. It retains the stock fuel pressure regulator plunger witch installs into the fuel bowl and uses a new spring and regulator housing. If you get anything between the plunger and the fuel bowl it will not seal correctly and bleed your pressure to you tank. At idle your fuel pump can keep up with the demands of the engine and leak by to the tank. Under load you are using more fuel and still leaking back to the tank causing you to have no power. I would do steps 4-8 on your installation sheet and make sure you don't have any trash between your plunger and fuel bowl and make sure your plunger does not have any damage. I know you just did all this not to long ago but you could of just got some trash in there recently and all it needs is cleaned. It should only take a little bit to remove and clean and reinstall for piece of mind. Also check to see if you have diesel in the coolant. If you do I would suspect injector cups.
01 f-250, Standard
sbluke55 is offline
post #10 of 17 Old 01-27-2014, 08:32 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
https://www.riffraffdiesel.com/conte...structions.pdf
Here is a link to the installation instructions.
01 f-250, Standard
sbluke55 is offline
