Super Duty failure in one hole - Ford Powerstroke Diesel Forum
post #1 of 34 Old 01-20-2014, 04:36 PM Thread Starter
gabegoforth's Avatar
As the title says Super Duty with dead holes particularly cyl 8. What's going on? I just bought a 01 that has a bad engine with no compression on one cylinder, haven't figured out which one, but my friend just replaced a engine because number 8 egged it self. It seems to be kind of popular for these newer 7.3 to do this. His had about 170k. The one I picked up has about 260k. I am going to bet that number 8 is also shot in this engine. What's going on that these trucks are failing more? Both of these trucks are clean trucks. Is the LL injector to blame?
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 34 Old 01-20-2014, 07:13 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 328 Post(s)
Its what happens when someone runs the truck with a bad injector. Diesel is oil based which naturally is a lubricant so when you drive say 200 miles on a bad injector it "washes the cylinder out". Ive replaced an engine that done the same thing and it was because of that.
@loxdce
LoxDiesel is offline
post #3 of 34 Old 01-20-2014, 07:15 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Number 1 or 8 is generally due to dusting
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 34 Old 01-20-2014, 07:16 PM Thread Starter
Nah. That's not how it works. The fuel is atomized. The cylinder is oiled from the bottom up.
post #5 of 34 Old 01-20-2014, 07:20 PM Thread Starter
Wonder why that is? Not the whole engine? This thing has blow by that isn't even puff puff. It's woot. This truck has a banks intake that isn't any better looking than a cheap kn that's got a bit of glory wrapped around it.
post #6 of 34 Old 01-20-2014, 07:22 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I remember reading something fairly extensive on it a couple years ago when I first got into 7.3's. It's the way the intake routes, the particles tend to take that path rather than the other cylinders, I can't remember the specifics anymore lol.
post #7 of 34 Old 01-20-2014, 07:28 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
banks intake lets lots of junk through.
there was another member who took off his banks ram air and put 6637 on, because after 3000 miles the banks intake let a lot of particles through.
the #8 cylinder is always affected more when dust and fine particles make it through the intake.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #8 of 34 Old 01-20-2014, 07:30 PM Thread Starter
Ok, I personally run a 6637. They seam to be really good filter.
post #9 of 34 Old 01-20-2014, 07:45 PM
LoxDiesel's Avatar
Quoted: 328 Post(s)
Ok then ever wonder why a 7.3 with 500k has no ring ridge? (Cylinder wear)
@loxdce
post #10 of 34 Old 01-20-2014, 07:50 PM
LoxDiesel's Avatar
Quoted: 328 Post(s)
@loxdce
