Oil Leak from dipstick tube at the pan - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-19-2014, 04:42 PM Thread Starter
SuperCrutyPS's Avatar
Quoted: 304 Post(s)
Garage
Today, I was out and about. When I got back, I had a drip trail up by driveway and then back to where I back in. At that point I thought it was coolant, but didn't check it. Then off to the grocery store. At the store, another trail and then noticed a puddle under truck. Went ahead and got groceries and cam home. Same thing. Trail up the driveway and then a puddle once I parked. I got under the truck and I see it leaking from where the dipstick goes through the pan. I get my channel locks and tighten the big nut that goes around it. Re-started the truck and it is still leaking. It looks like it's leaking around the threads of the assembly. The truck has ~204,000 on ODO.
I don't want to drive it this way given the engine's requirements for oil.
How big of a deal is it to get this fixed? A shop trip? Big $$???
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #2 of 4 Old 01-20-2014, 07:38 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
SuperCrutyPS (01-20-2014)
post #3 of 4 Old 01-20-2014, 08:52 AM Thread Starter
Quoted: 304 Post(s)
Garage
Thanks for the info. It was leaking a lot of oil before I tightened it. I was hoping it would slow it down. After looking the info you provided, it is most likely the internal o-ring that failed.
Now the question for me is....Am I brave enough to do it myself?
My Truck Garage:
Tow Toy Garage :
post #4 of 4 Old 01-26-2014, 10:09 PM Thread Starter
Quoted: 304 Post(s)
Garage
I was talking to a guy who used to be an auto mechanic. He suggested using a high-temp RTV. I got the red stuff and some brake clean. Saturday, I pulled the positive cables off the batteries, yanked the starter and loosened the nut. I left the dipstick in to help keep the internal piece from falling in the pan. I cleaned it all with the brake clean. I spooged the threads, waited a bit before putting the nut back on and snugged it up. I put some extra on where the threads of the nut and internal piece meet. I re-installed the starter, hooked up the batts. I waited until today to start it up. No leaks, at this point anyway. I let it warm up while I set the clock and re-saved my radio stations. I revved it up for a bit and no leaks. I'll drive it this week to see how it holds up. I may still have to do something more expensive later, but for now it's working.
My Truck Garage:
Tow Toy Garage :
